Question about KitchenAid KUDU03FT Built-in Dishwasher
The top rack is not cleaning dishes - KitchenAid KUDU03FT Built-in Dishwasher
  • KitchenAid Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
putkur
Posted on Sep 29, 2010
SOURCE: top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Posted on Oct 06, 2007
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
  • 744 Answers
SOURCE: dishwasher not cleaning dishes on top rack
Check the riser tube coming from the pump assembly and be sure it isn't blocked or that something else isn't obstructing the pump intake area. Make sure the upper wah arm assembly isn't excessively loose on the spindle and losing pressure because it's leaking. You may have to remove the lower rack, lower wash arm and cover to see.
If everything is clear, it could be a worn or damaged pump impeller. If the machine drains normally, it's not the motor.
Posted on May 16, 2009
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
The top rack is not cleaning. The dishes on the bottom rack come out clean but the ones on the top rack don't look like they have even seen water?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
Oct 19, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Nov 25, 2008 | Dishwashers
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
May 05, 2008 | Kelvinator MDB121RF Dishwasher
KitchenAid KUDU03FT Built-in Dishwasher Logo
76 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
