Where can i find Xerox Document Centre C400 service manual and system software setting?
    President:
  • 2,306 Answers
You might try for help at www.partsdrop.com
Posted on Jul 16, 2009
Fuji xerox document centre 350 manual to download?
The User's Guide for the Document Centre 350 is available from the product support page. There are two files (one for the scanner and one for the printer). See http://onlinesupport.fujixerox.com/processDriverForm.do?ctry_code=TW&lang_code=en&d_lang=en&corp_pid=DC350&rts=null&model=Document+Centre+350&type_id=5&oslist=Windows+95&lang_list=en and the Documentation tab. The drivers are available for supported OS versions on the Drivers tab.
I hope this helps.
Jun 27, 2013 | Office Equipment & Supplies
FUJI XEROX Document Centre C400 can't set custom paper size
I found that I needed to be logged in as the Administrator for Win 7/64 before I could edit the custom paper size in the advanced printer settings for my P205b.
The printer driver has a stupid feature where you have to specify custom sizes privately to the printer driver before you can then choose that size in your application; you can't just enter a custom size in your application.
You also have to specify if that paper is to show up at 1:1 or some scaled value.
Because the driver didn't have A6 in its private list of paper sizes, I couldn't print in A6 at 1:1 because selecting A6 in the application produces a message saying that you can't print A6 at that scale factor!!!!!
Jun 16, 2012 | Office Equipment & Supplies
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Nov 23, 2009 | Xerox Document Centre 420 DC Laser Printer
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Aug 02, 2008 | Xerox WorkCentre M123 Copier
357 people viewed this question
k24674
