Question about Cuisinart Brew Central 12-cup Coffee Maker
Coffee does not drain from filter basket into carafe. Stays in fi
I use the correct paper filter, add water, etc., but the coffee does not drain from the filter basket into the carafe at all. After having this coffee maker 2 years this just randomly happenned. I removed the filter basket, looked at the bottom where there is a small spring action "thing" that I can push up and down and that allows the coffee to then flow into the carafe, but only if I manually push the spring action "thing" myself. Can I get a replacement piece or something?
  • 2976 Answers
SOURCE: Can I adjust the water flow for finely ground coffee?
You probably have coffee ground for a drip coffee pot, not an automatic drip coffee maker. With a drip coffee pot, you put the coffee in and add the hot water on top of that. You might want to try a coffee press. They are fantastic for the finer grinds of coffee. Some Mexican coffees are ground almost as fine as flour and a press works great. You can get a press for about $12 & up.
Posted on Jan 30, 2009
SOURCE: The carafe dribbles coffee when pouring.
This has been a problem with many carafes. I tried something I saw on a home show once, and it works, but... it may seem weird and undesirable. Unless you pour just the tiniest stream, the liquid wants to stay with the pot, you see. It will be attracted along the spout back down the pot, causing the dribble.
Put just a tiniest smear of shortening or oil on the pouring lip, and the problem will instantly disappear.
You've already guessed the undesirable part of this, right? Yep. It doesn't last for long because the hot water cuts through the film after a few pours. And, who wants Crisco in their coffee?
I didn't notice anything different with my coffee when I tried it. Probably not enough grease to make that much difference.
But the "back-drip" ended pronto.
Joe Java Lover
Posted on Feb 01, 2009
SOURCE: bosch porsche 9110 drip coffee maker
mine just broke this morning! i just ordered the same part from appliancepartspros.com - the part number is AP2807555. It is currently backordered until 4/25/09 - hopefully I will get that and the other part I ordered. Hope this helps.
Posted on Apr 15, 2009
NewsView
  • 40 Answers
SOURCE: cusinart 12 cup grind and brew overflows with grinds and water
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
SOURCE: water leaks out between coffee brew basket and
If you are noticing the water that is leaking at the base, I was having the same problem. If you can specifically see that the leak is coming from between the basket and carafe - then you may have a different problem. My problem appears to be that the heating element is shot - it leaks when you start the brewing cycle. I found this out by taking off the bottom and raising up the coffee maker and puting it on a mirror to view what was going on. As soon as the brewing starts and the system is under pressure, water starts forming on the metal tubing part of the heating element. I suppose it's possible that water is leaking down from the tubes, but it looks like it is getting forced out of the metal, so there must be small holes, caused by corrosion. I will check further but I can't find a replacement heating element online so I may have to purchase a new coffee maker.
Posted on May 07, 2010
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
The filter is filling w/ liquid instead of draining into the coffee pot.
The release button on the bottom of the grounds basket is not working or the small drain hole is plugged. Make sure that you are using the correct size #4 paper filters to hold the coffee grounds. Remove the basket and check to make sure that the release button is working freely. Put some water in the basket and push the bottom of the basket. The water should drain. If it does not drain, You will need to replace the basket assembly.
Check the carafe to make sure that the lid of the carafe is pushing the drain button up to release the liquid in the basket.
Let me know if you have any other questions. Thanks.
Jan 13, 2011 | Cuisinart DCC-1200 Coffee Maker
Just bought a new Bunn Thermafresh and it overflows coffee grounds and coffee all over. What can I do?
1. Don't overfill the basket with grinds.
7. Make sure that the Pause 'n Serve button isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
Nov 04, 2009 | Bunn NHB Coffee Maker
Coffee has doesn't drain into the carafe and just overflows all over the counter
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine or too course. (See instruction manual.)
4. Make sure the filter cone/basket clicks into place and that the carafe is pushed all the way in.
7. Make sure that the Pause 'n Serve isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Make sure the coffee machine is sitting level on the counter.
Oct 05, 2009 | Zojirushi ECBD15BA Coffee Maker
When brewing the coffee at times the water stays and almost overflows where the filter and coffee is rather than brewing properly- what could this be and how to fix it?
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Aug 13, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker with grinder--sometimes, when percolating, it overflows
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cusinart 12 cup grind and brew overflows with grinds and water
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Water overflows from filter basket
Dec 25, 2008 | Mr. Coffee ISTX95
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee overflows
I have a 1600 with the same problem. The problem is due to a poorly designed fit between the carafe and the drain plunger in the coffee basket. If you lift the carafe slightly, you will see the plunger has a long way to go. If you have the tendency to push the carafe fully to the back of the hotplate it makes this worse. OK, so now the fix, which worked for me. Find a small piece of plastic to glue to the top of the carafe lid. You just need a small dimple to push the coffee basket spring in further when you in sert the carafe on the hotplate. You should experiment a little first to see how thick it needs to be. Overall it's a poorly designed combination and someone needs a lesson in tolerancing.
Jun 06, 2008 | Cuisinart DCC-1200 Coffee Maker
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
229 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
