Question about RCA WSP155 Main / Stereo Speaker
Rca 155 Wireless Speaker transmitter not working. Power Led flashes then goes out???????
    Problem Solver:
  • 7 Answers
You probably have the polarity on your plug to the transmitter set on the wrong one. Set it to negative frequency, and it will probably work. I've had the same problem myself.
One other possibility: the Music has to be coming through for the light to go on, so if the music is too soft, you might not get any sound through. Good luck!
Posted on Aug 28, 2009
  • chris Feb 02, 2012
    the light is not meant to be a power ac indicator light, when it is plugged in, the light ONLY comes on when incoming audio is detected...
Klipsch Lightspeaker 5.2 One speaker will no longer communicate with base.
Hello Beerisfood,We are the Canadian distributor of the LightSpeaker. Sometimes very rarely the LightSpeaker may "un-pair" and "re-pairing" the unit to the base is needed. It takes under 10 sec and is very easy to do but must be performed in a specific manner. 1. Power to the LightSpeaker must be off.2. Turn on transmitter (base) 3. Press the "pairing" button on the transmitter (base)
-lights will flash on the transmitter, during that time that they flash, turn power "on" to the LightSpeaker. The light on the LightSpeaker should now be green.
Youtube has a great video as well on pairing. Type Klipsch LightSpeaker and the first video should walk you through the process. If that does not work contact www.lightspeaker.net as they are the manufacture of this product.(Klipsch was just the US distributor not the manufacture)
Hope that helps.
Jun 02, 2012 | Klipsch Lightspeaker 5.2.0 Wireless Sound...
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
When I plug in the power supply to the transmitter the green light goes on only for a split second and goes out. If I wiggle it back and forth and it and out I can't get it to ever find a spot where it...
the sound source MUST be hooked up and running INCOMING SOUND to trgger the transmitter to work.the green light DOES NOT STAY on simply powering up the transmitter......
Jan 15, 2011 | RCA WSP150 Main / Stereo Speaker
Sound cast will not play from my ipod by wireless green light on speaker blue flashing light in the transmitter
Usually this happens when you have a damaged power supply. Once you replace it everything goes back to normal. You can contact tech@soundcastsystems.com for support on this.
Dec 01, 2010 | Digital Media Soundcast ICT-111 iCast...
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Transmitter light does not come on
Just switch the polarity on your plug from positive to negative...it will work!
Dec 31, 2008 | RCA WSP155 Main / Stereo Speaker
Wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Dec 30, 2008 | Computers & Internet
Bought a Shift wireless indoor/outdoor speaker from Office Depot & enclosed AC adaptor Model RGD48120120 plug is too big to fit in the plug hold on the speaker unit
if it packaged with the speaker, then its office depots fault. i would replace it with another before the warrenty is out of date.
Oct 24, 2008 | Audio Players & Recorders
Wsp150 transmitter failure
The following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume. If the volume is too low, the transmitter will not turn on.
Apr 01, 2007 | RCA WSP150 Main / Stereo Speaker
RCA WSP155 Main / Stereo Speaker Logo
883 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
