Question about Honda Garden
Idles very good but will not run at full thortle for any length of time. Honda 25cc tiller.
  • 112 Answers
Gas cap not vented or high speed needle not out far enough.
Posted on Jul 17, 2009
How do you change the oil on a honda fr 800
-Open oil filler cap or plug at front (Flat Plastic knob) then just till to the front to drain it until no drip then just re fill w/ 10w30 to full level. You're good to go.
Good luck
Mai
Jun 21, 2014 | Honda 25cc 4-cycle Mini Tiller
Honda 25 cc 4 cycle mini tiller how to adjust carburator
With one screw you can adjust the idle speed, and with the second, located under the carburetor you can adjust the running or load speed.
Mar 22, 2013 | Honda 25cc 4-cycle Mini Tiller
Honda fg100a wont stay running full of fuel and oil
I had a similar issue. Tiller starts and runs for 20 secs. or so then dies. Found the problem! In turning the tiller on its side to check model numbers etc. the fuel line had shifted inside the tank and was stuck just about at the TOP of the fuel level. When I gently pushed the fuel filter and line back to the BOTTOM of the fuel tank, the tiller now runs beautifully! So, check that the fuel line placement inside the fuel tank is correct.
Sep 29, 2011 | Honda 25cc 4-cycle Mini Tiller
Tiller engine after getting warm stops. I have changed the spark plug, cleaned the carb and replace fuel but still hav the same problem. It always fires back up and is good at the idle but when at full...
check for a full fuel flow to the carby
indicates a low fuel level possibly float level
check that there is a heat insulation block between the head and the carby
maybe head heat is tending to boil off the carby fuel if too low a level
Dec 18, 2017 | Honda 25cc 4-cycle Mini Tiller
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine stalls at high rpm.
Clean your filter, check your plugs and if it still cuts out tighten up your throttle adjustment while you have it idling until you find a good purr.
Jan 27, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Mar 16, 2009 | Honda 25cc 4-cycle Mini Tiller
Garden Logo
195 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
