Question about Sony Cyber-shot DSC-W80 Digital Camera
Flash won't turn on
I just bought this camera and after a week and very little use the flash won't turn on. I know how to change the flash function, but it says it cannot be changed. It's in "force off" which I do not think I ever put it into that mode. Does anyone know how to turn it back on?
Re: flash won't turn on
Thanks so much! I was driving myself crazy :)
Posted on Dec 25, 2007
0 characters
3 Points
I accidentally dropped my samsung S1070 while I was taking a photo, and the lens is now stuck out. It won't turn on, and we've tried replacing the batteries and taking them out. I've also tried...
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Sep 04, 2011 | Samsung S1070 Digital Camera
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
I bought a tasco trail camera and had 29 pictures and 25 of them were just a blank black pic. Help!!!!!
Those are night time photos and your flash is not functioning. The capacitor is burned up. Somebody could make a fortune selling the capictors because these little $50 pieces of WalMart **** are only meant to last one deer season, or about 8 weeks. A common problem, but apparently guys who forget a password is even more common. You do not need a password. Skip that step.
Dec 01, 2009 | Digital Cameras
Nikon D80 - My (built in) Flash will not pop up.
That is just a mechanical problem. There is just a little hook holding the flash and it retracts when you push the bottom to pop up the flash. I'm sure it can be easily fixed, never the less your camera store or Nikon should take care of it. So take it back to the place you bought it.
Jun 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Question to your answer
in playback mode, press the up/down arrow and it should change through various settings until you are back to normal, non-flashing highlights.
Sep 24, 2008 | Nikon D40x Digital Camera
Review isn't working
This is not a problem. This is a function that shows you the "burn" area at the photo. If you wishes to drop it just rotate the command dial at rear of the camera. You can change the option by changing the menu as shown at page 75 in the manual.
Sep 23, 2008 | Nikon D40x Digital Camera
Problem with slr camera flash obstruction
The problem is in the flash pop up switch. It is probably jammed in or there is some kind of substance on it causing it to stick. You can find it by manually popping up your flash. You should then see a little black spring loaded post on the release button side of the flash. Check to see that it is not stuck in in any way. If so that is why you are getting error 5. To repair you can try a qtip an a little rubbing alcohol. Otherwise you will need a technician to do it.
Dec 04, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Flash not working on Sony CyberShot DSC-P93A digital camera
The flash on my Moultrie gameSpy 4.0 (D40) quit working. I can trigger the camera and see the flash is very week. Batteries are 100%. Can the flash be ordered and replaced?
Nov 11, 2007 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Lens will not retract
I had exactly the same problem and I went to this site and got my solution. I banged the bottom of the camera with my palm and turned it off and on at the same time. On about the fourth bang the lens retracted and cleared the error codes. I know, "Caveman Maintenence" but it worked. Can't hurt to try...
Dec 10, 2006 | Kodak EasyShare CD33 Digital Camera
Going through batteries abnormally quickly
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
May 31, 2006 | Canon PowerShot S1 IS Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
50 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
