Question about Garmin Forerunner 405 Handheld GPS Receiver
Garmin 405. When I press GPS is shows the compass. Apparently if I tap the bezel again ... I should get some menu items with choices. This does not happen. Why?
SOURCE: Can't get my GPS to turn on with the Garmin 405
I too was frustrated because of this. I played with the watch until I found the solution. Hope this helps!
For some reason I needed to be in the training mode to do this.
From the Time/Date mode, do the following:
1.) Press the start/stop button (upper metal button) to get out of Time/Date mode
2.) Press the Training side of the bezzle. You will see a workout display.
3.) Touch the GPS side of the bezzle until "to location" shows up
4.) Press the lap/reset button (lower metal button) to display a menu (may have to do this a couple of times, eventually when you release the button the menu does show up)
5.) Slide downward through the menu options until you find GPS
6.) Click the start/stop button (upper metal button) to toggle the gps on or off
7.) Press the lap/reset button (lower metal button) to exit the menu (goes to the "to a location" screen)
8.) Press and hold the Training side of the bezzle to return to your training screen
Posted on Apr 26, 2009
  • 6 Answers
SOURCE: Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
Posted on Jun 24, 2008
RixsFixes
  • 2200 Answers
SOURCE: Garmin nuvi 250W Car GPS Receiver
When you have the screen showing up the route to your destination, if you touch the box down in the left hand corner showing the estimated arrival time the screen should switch to show your current speed, max speed, compass etc.........
Posted on Jun 21, 2009
SOURCE: Garmin Forerunner 405 always shows wrong time/date
Turn on the GPS. The forerunner will automatically sync time and date. Make sure the DST is switched to auto. I had the same problem and researched for the answer....which led me here. Turning on my GPS sync'd time and date for me. I hope this helps
Posted on Nov 01, 2009
MicroSofty
  • 75 Answers
SOURCE: How do I calibrate my compass in the eTrex Venture
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
Posted on Dec 31, 2009
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
Compass 'pops up' in middle of a training run - want to stop this
You are in the mode that is used to navigate to a location. When the compass is up, hit the "quit" button, then select "stop go to" and it should stop.
Jan 25, 2010 | Garmin Forerunner 405 Handheld GPS...
Goes to compass after seacrhing for satellite
It might the default setting. There should be a way to change it.
Nov 21, 2009 | Garmin Forerunner 405 Handheld GPS...
Forerunner 405 completely frozen
I had exactly the same problem. i looked through this site and found some advice that said to hold both buttons (quit/enter) for 7-10 seconds, which resets, but apparently doesn't wipe your info - happy days :)
Jul 12, 2009 | Garmin Forerunner 405 Handheld GPS...
I cannot clear a 'to a location' screen
I too was frustrated with this one. I played with the watch until I found the solution... Hope this helps!
Apr 02, 2009 | Garmin Forerunner 405 Handheld GPS...
I have a garmin Forerunner 405 and the time was locked at 7:25 am.  I held the two side buttons down in an attempt to reset it, and it just cleared the screen completely.  I charged it last night, and the...
Hi
I had a similar problem, the screen lock while trying to turn GPS on. Tried all butttons and bezel operations, left it charging overnight - no joy. Eventually pressed and held both buttons and after about 30 secs (did not time it but was about that) it restarted.
AllanD
Jan 16, 2009 | Garmin Forerunner 405 Handheld GPS...
Jan 02, 2009 | Garmin nuvi 200W GPS
Nov 16, 2008 | Garmin Forerunner 405 Handheld GPS...
Compass deos not point north
do a calibration. press the menu button while on the compass screen and select calibrate.
Jun 07, 2008 | Garmin eTrex GPS Receiver
Garmin Forerunner 405 Handheld GPS Receiver Logo
615 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
