Question about Smart Modular SV3170A
Does samsung monitor save power in sleep mode?Or will it just displays black all over the monitor?
  • 81 Answers
Yes, all monitors work directly with the cpu, the cpu sends message to the monitor, so if the system is in sleep mode, automatically the monitor stops work excepts the cpu comes up again then the monitor wakes, in a nutshell, a monitor is connected to power while in sleep mode but has no signal to function
Posted on Jul 17, 2009
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Flatron W1943 sb monitor goes into power-saving mode. Does not display data.
If the monitor is displaying the "Power Saving Mode" signal to the monitor, then the monitors internal VGA board is functioning, so you can rule out a broken monitor. However I have seen monitors blow the internal fuse to the VGA board which causes a false "SLEEP" signal. If this be the case then it will require replacement of the fuse (usually a microfuse soldered onto monitor internal board) or most likely a monitor replacement.
To test:
Option A: you can connect another monitor to the monitor output on the back of the computer and see if you get a display. If this monitor goes to sleep, then it is likely that your Video card is malfunctioning. If you get a display, then it is definately the monitor.
Option B: If you have another computer, you can attempt to connect the monitor to another computer. Also most modern laptops will be equipped with monitor output, so if you have one you can check it. If the monitor sleeps, then it is definately the monitor. If you get a display, then it is definately the computer video card.
Hope that helps,
G
Sep 17, 2012 | Computers & Internet
Samsung syncmaster 226BW fails to wake up.
If pc not sending it to "sleep mode" or "power save" mode, then unit may need help of electronics technician to investigate the "internal switch-mode-power-supply" that may be going into "shutdown" mode after it detects a "fault condition" with itself or onother circuit.
12fixlouie
Sep 20, 2010 | Samsung SyncMaster 226CW 22" Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Sleep mode
Does the monitor go to sleep when you unplug the video cable? If so, then the computer is still sending a signal, if not, check the monitor menu settings for no signal settings.
Apr 25, 2008 | ViewSonic VX2435wm (Silver, Black) Monitor
Stuck in sleep mode w/black screen
If possible, try a friends monitor first. If it works, you can then change the sleep mode setting so that it won't come on again. If the other monitor does not work, the video card is probably defective.
Oct 26, 2007 | Computers & Internet
Smart Modular SV3170A Logo
225 people viewed this question
Top Smart Modular Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
