SOURCE: I was given a Kenwood KDC-1011S. All wires labled
Yellow is for constant 12v. (Power directly from battery) so it maintains preset stations and clock memory. Red is for Key "on" 12v Power (turns on when ignition key is on) Black is for Chasis Ground. What type of vehicle is it going in? I can get you the corresponding vehicle color as well. Post a comment with make/model & year vehicle. Hope this helps.
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
SOURCE: New KDC-135 has Power but Faceplate won't light up
you shold always twist the end of the wiring together and tape them never use connectors, remove the connectors and twist the wires driectly to each other and tape them wiht electrical tape, the connectors almost always can not deliver the proper voltage..
Did you make sure you have the yellow to a constant connect wire and the red to a turn on?if not this can cause the radio not to work......
you can test wich is wich by turning the key off and putting the yellow to the one you think it is and red to the one you think it is, if you have have it right you will hear the CD player make a click run sound...... if not you will not hear any thing.
SOURCE: kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
SOURCE: need wiring diagram
red is power,yellow is constant 12v for memory.blue is power antenna,purple and purple with stripe is rear right speaker,green and green with stripe is rear left speaker.white and white with black stripe is front left,and gray and gray with black stripe is right front speaker. the power antenna can be used as a remote source to turn on the power amplifier.
