Question about Hayward Sand Filter System & Tank 21" 1 1/2 Hp
HOW DO I CALCULATE THE HEAD OF A SWIMMING POOL WATER CIRCULATING PUMP
    President:
  • 1,714 Answers
The pump is rated to produce (x) amount of GPM. (gallons per minute) If your wondering about the pressure the pump will produce, It depends on a lot of variables, like at what point in the system output you measure and how far from the pump (friction loss). The pump name plate should show some data, start there. Go online and get the data for that specific pump. Check with Mfg of pump.
Posted on Sep 01, 2009
The length of a pool is 10 ft, the width is 10 ft, the volume is 2,700 cubic ft. we are trying to find out the height.
V = L x W X H
2700 = 10 x 10 x X
2700 = 100 x X
x = 2700/100
x = 27
You should be able to do that in your head.
Mar 10, 2015 | Blue Wave Swimming Pool & Spa Above-Ground...
Tip
Simple keys to a beautiful clean pool.
There are 3 keys to a clean swimming pool; filtration, circulation and chemistry. Not having the right amount of any one of these keys will soon cause the pool to be dirty. Filtration requires a filter that allows enough flow and catches any particles in the water. Circulation means enough water is circulating. Chemistry is having the chemicals to the right levels in the pool. The most important component to accomplish these keys is the pump. If the pump doesn't work then the filter doesn't work, the water is not circulating and since chlorine feeders need circulation to deliver enough chlorine to the pool, not having a working pump quickly causes the pool to go green.
on Aug 11, 2011 | Intex Easy Set Pool 15x36
Tip
Simple keys to a clean swimming pool.
There are 3 keys to a clean swimming pool; filtration, circulation and chemistry. Any one of these keys will soon cause the pool to be dirty. Filtration requires a filter that allows enough flow and catches any particles in the water. Circulation means enough water is circulating. Chemistry is having the chemicals to the right levels in the pool. The most important component to accomplish these keys is the pump. If the pump doesn't work then the filter doesn't work, the water is not circulating and since chlorine feeders need circulation to deliver enough chlorine to the pool.
How many gallons of water in 3172 cubic feet of water?
There are 7 1/2 gallons of water in a cubic foot.
3172 x 7.5 = 23,790
To calculate how much water in a swimming pool, in 'US Feet':
Length x Width = Surface Feet
Surface Feet x Average Depth = Cubic Feet
Cubic Feet x 7.5 = Total Gallons
Mar 07, 2015 | Pool & Spa
I cannot start pumping. the pump runs but no water is circulating
I think you have spun the center out of your impeller. Disassemble your pump and replace the impeller if necessary. Also replace all seals while you are at it.
May 04, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Noted decrease in suction power and outflow. the first couple of uses this season the suction and outflow were notably strong. now there is hardly any force at all with the water circulating through the...
Remove the cartridge and see what happens with the flow. If the flow returns to 'normal' with no cartridge, that tells you the cartridge needs cleaning or replacement.
Apr 30, 2011 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Hayward Sand Filter System & Tank 21" 1 1/2 Hp Logo
224 people viewed this question
Top Hayward Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
