Question about Samsung Televison & Video
My Samsung Projection HD TV is shutting down after being on for five minutes.
  • 261 Answers
Have you replaced the lamp before? if not I recommned you do it, bc it might be the issue, if you already replaced the lamp it's more probable that you have a defective ballast, with samsung tvs, besides the lamp, the parts that are more common to go out are ballast and colorwheel, for a more accurate opinion if you like discountdashmerchantdotcom
Posted on Jul 16, 2009
Samsung LN46A580P6F LCD HD TV is turning on and off from two to ten times before it stays on when the tv is cold
Samsung LN46A580P6FX
On the main board, IC104 (Part #SPX1587AT) is a 3.3VDC to 1.8VDC regulator. When this IC fails, the 1.8VDC drops substantially when the TV is turned on. After five minutes or so, the unit operates fine. This IC can be purchased from digikey for about $1.80.
Another fix is to attach a 1000uF 10 volts capacitor from ground to the DC source of this IC. I used a 1000uF 50V (overkill) for proof of concept. See attached pictures.
Dec 17, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv shuts off within five min. light bulb was replace and its still shutting off. HLR6867W samsung
U hear alot of clickings,when turn on the tv?Ur Ballast board is dead.The ballast board to help it to light up the projection bulb.
Jun 06, 2010 | Samsung HLR6768W 67" Rear Projection HDTV
Auto Shut-off when screen changes colors
Sounds like your tubes might be going. Very expensive to replace them. Eventually tv will go into shut down. Watch it till it goes. Can have professional adjust tubes once its in shutdown to squeeze some more life out of it
Apr 09, 2009 | Sony KP-57WS500 57" Rear Projection...
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Unit shut down after five minutes
From the brief description of your problem it sounds like you have a component in your unit which is overheating after a short time and shorting out causing the set to shut down. It could be anything. If you are not a tech you will need to find a reputable repair shop. I doubt you could find this, most techs will have problems with this one. Cost should not be that much. The biggest problem will be finding the problem. Good luck.
Jun 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
