Question about GE WBSR3140D Top Load Washer
Refills with water between loads - GE WBSR3140D Top Load Washer
    President:
  • 1,776 Answers
A defect or an obstruction in the water level switch may mean that it can't tell the water to shut off. The switch senses the water level in the clothes tub. It is usually a diaphragm type device that has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the tube. Once a certain amount of pressure is applied, it trips the switch to shut off the water and signals the timer to start the wash cycle. You can either clear any obstruction that might be in the tube or replace the water limit switch. Hope this helped.
Posted on Jul 16, 2009
Our topload washer sometimes refills after we have
Check your drain hose it may have a kink in it so will not drain properly and will back up with the water remaining in pump or The hose is is to far down the drain pipe.
Mar 28, 2010 | Washing Machines
Water refills after a complete cyle. GHw9100L
Had similar problem and ended up being the valve. Try shutting the water off to the wahser during the spin cycle. If the water doesn't refill, that is the issue.
Mar 28, 2009 | Whirlpool GHW9100L Front Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Samsung, rossby washing machine
There is a capacitor linked to your motor by wiring.. That capacitor is most likely the fault... It is normally a 400vac 12UF(J) capacitor
Jul 10, 2008 | Samsung Washing Machines
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Water in machine
does it actually refill with water or is the water still remaining from that load? i recycle my water though a hose to use on my garden if it dosent run freely and quickly enough water will still remain in my machine sometimes nearlly half a load. that makes me think it could be your drain the smell would suggest slow or sitting water which could indicate obstruction along the line somewhere.check as much length of the drain as you can my drain outside has a u shape where things can build up there is also a removable cape so at least you can stick something down there.
Dec 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE WBSR3140D Top Load Washer Logo
70 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
