Question about Neovo AG 17" LCD Monitor
AG Neovo X-17a
I also have the same problem as listed in here. there are some weird things going on with the screen.
On all my PC's this screen does not function. ( i have 3 windows and 2 in linux )
When I power on the PC I can see that it is counting memory for 1 second then the screen goes black... when I keep the PC on I can also see after a short while that windows is loading (logo) with the progressbar already halfway.. Then the screen goes black again after that 1 second... The last time I can see something is when the screen displays the logon screen for windows for the same 1 second time.
During these times the image is crisp clear and very bright.
In the linux machines I have not witnessed from startup, rather I connected it to a loaded machine and turned it on. The result was a short message from the OSD that something was not supported and the screen turned black again.
Everytime I turn off the monitor and turn it back on (move the mouse) I get the screen for about a second.
The OSD is not visible and the auto adjust functions don't seem to work.
Perhaps the screens brightness or contrast or something settings are lost or turned down. Can anyone report how the menu is layed out? Or is it a hopeless case?
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
Display picture dancing & lining
plz change your desply screen than fault cilear
Jul 22, 2013 | Neovo AG E-17A 17'' LCD Monitor
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
I own an AG SX 17 neovo monitor, which I got from my company; as they were going to throw it away because the light of screen decreased and after 2 seconds the screen would go blank. When I turn it off and...
a lot of monitors are having trouble with defective capacitors in their power supply ...the bad capacitors will usually have their tops buldged up .. they are not expensive but you would need to know how to solder and basic electronics .
Apr 02, 2010 | Neovo SX-17A 17" LCD Monitor
The sceen is black but wen u press the power
Stefieanne, The long, thin, "cold-cathode-fluorescent-lamps" are not staying lit anymore. Unit's "switch-mode-power-supply/CCFL inverter supply will need REFURBISHMENT to restore proper operation. SOFTWARE WON"T HELP YOU!!!!! Visit all links you find while doing some reading in my fixya profile to help you in the big decision you will need to make on what you will do with this "black" or "blank n black" screen ccfl back-lit lcd monitor. Do you have soldering pencil of about 35 watts and some solder and pliers and screwdrivers and even a digital voltmeter. Contract out the work $35 to $90 Tell us what your intentions are. 12fixlouie
Mar 21, 2010 | Neovo AG E-17A 17'' LCD Monitor
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as service.us@agneovo.com to have a RMA number and they will estimate you the repair fee if it is out of warranty.
Jan 06, 2010 | Neovo E-19A 19" LCD Monitor
Monitor shows cctv for 2 seconds then goes of? Why.sx 17a monitor
Dear sir pls match the colur system standard of CCTV out & ur monitor Video in , U might be using a PAL camera on NTSC input or vice versa
1) ur monitor may not be supporting low resolution try NTSC/PAL to VGA convertor box ..
Mar 20, 2009 | Neovo AG 17" LCD Monitor
Screen Goes Black After Monitor is on for a while.
Bad CCFLs in your LCD. CCFL stands for Cold cathode fluorescent lamps. These are the lamps that provide backlight for the LCD Monitor. These lamps do not last forever, and are a very common part to go bad. The circuit that provides the power for the CCFL is called the inverter, it might be going bad, but I still think it is the CCFL. Only trained techs should try and replace a CCFL or fix an Inverter. CCFLs do contain mercury, but only small amounts.
http://en.wikipedia.org/wiki/Cold_cathode
My advice, get a new LCD monitor and sell your bad one on ebay.
Nov 16, 2007 | Neovo SX-17A 17" LCD Monitor
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
Oct 30, 2006 | Neovo E-19A 19" LCD Monitor
Neovo AG 17" LCD Monitor Logo
1,105 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
