Re: the cutting blade with rubber (the total part) is...
Send an e-mail to [email protected]. They will contact you with the info you need. They were kind enough to send me an extra gasket (at no charge) for my blender that was leaking.
Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
If you have the glass jar then purchase either a new rubber seal for the blade to jar fitment or replace the blade assembly, it will be one or the other. If you have plastic beaker then get a new beaker, it is sold as a single assembly.
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread. The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE. Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks. This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
