My home's Air Conditioner shuts off and on until reach temperatur
My home's Air Conditioner shuts off and on every few minutes until it reaches the set temperature. And sometime when the setting temperature is reached, the air conditioning stopped first and then turn on to run a few more minutes, and then stop completely. What's wrong?
    Scholar:
  • 91 Answers
You have some issues that probably need to be addressed by a Certified Tech asap. There's an off chance that it could be just thermostat related. If you feel confident on doing what I'm about to instruct go ahead and try it.If you turn off electricity to your unit(should be marked as A|C or furnace or the like if you have the unit on and turn off at the panel it's easier to locate) you can take the cover off your thermostat and you will find various wires. Unscrew the R, Y, and G wires(if they;re not colored red yellow green make a diagram as to which goes where) and twist them together, Then turn electric back onto unit. If the unit runs normally as it should, then you have a thermostat problem and need to get a new one right away. Remember you unit is worth $2,000 to $6000 don't let and electrical malfunction compromise the value, if it.s not the thermostat get someone qualified to look at it. Leave it off til they get there. Good Luck
Posted on Jul 16, 2009
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Motor shuts down when reaching normal operation temp
Sounds like the mass air flow sensor or the air intake temperature sensor. Sometimes just wiping out the throttle body/air intake can make all the difference
Good Luck and Happy Motoring
Jun 22, 2017 | 2000 Dodge Durango
Can i set it to a temperature that will allow it to turn on and off automatically
Any temperature you set it at, the AC unit will turn ON and OFF automatically. Once the set temperature has been reached and held for 5 minutes, the unit turns OFF, but the fan may continue to blow for a few minutes. When the room temperature rises above the set level, it will automatically turn ON again and continue to run, until the set temperature is reached and it turns OFF.
I really hope this has helped you and thanks for choosing FixYa.
Jul 21, 2011 | Whirlpool ACQ158XP Wall/Window Air...
After my air conditioner is on for awhile it will automatically shut off completely then after a few minutes it comes back on. It is not set on the energy saver setting. Also it is and continues to do...
Debi, it;s not unusual for an AC unit to turn ON & OFF. Once it reaches the temperature that you have it set ON and holds the temperature for 4 or 5 minutes, it will shut OFF until the room temperature rises above it. Be sure all the doors and windows are closed and no hot air is infiltrating the area.
Also, a 10,000 BTU air conditioner is not designed to handle a large area. Generally, 10,000 BTU's will handle about 3200 Cubic Feet (20' x 20' x 8' = 3200 sq ft) or simply put, 400 square feet. Your A/C unit may be undersized for the area you're trying to cool.
Hope this helped you. Please let me know. Thanks.
Jun 07, 2011 | LG Electronic Window Air Conditioner
Unit runs fine until it reaches temp and then you hear relay clicking and the compressor tries to restart and hums and the relays continue to click. If you shut it off for a few minutes it runs fine until...
Sounds like either the temp unit or sensor may need to be replaced. You should also check the resistance of your relays with a multi-meter to check that they are not causing the problem. Checking the power from power-supply would probably be a last thing to check for.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
How do you set the temperature
If you have an air conditioner with a temperature display, use the up or down arrows on the touch pad to change the temperature setting.
However, if you have an air conditioner with only a dial that goes from 1 to 8 (or whatever number), turn the dial up as high as it goes and put the fan speed on high. When the desired comfort level is reached, slowly turn the dial down until the compressor just shuts off. You will be able to hear when this happens.
If the temperature gets a bit too warm turn the dial up in small increments and wait an hour or so to see if your comfort level is reached.
Jul 03, 2009 | Heating & Cooling
Heil heater starts/stops before reaching temp
is installed in a vertical up flow or horizontal position , if in horz position you could have a bad or miss positioned roll out switch this is a thermal switch positioned toward the burner edge that if the flame rolls out of burner area trips and then resets as it cools allowing the furnace to re-start until it reaches temperature , something to check .
Dec 08, 2008 | Water Heaters
Air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Jun 14, 2008 | Kenmore 72055 Air Conditioner
Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Jun 10, 2007 | Magic Chef CGR1415AD Gas Kitchen Range
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
