Toyota Yaris Main and Big end Torque settings:
Tighten the main and big end bolts in sequential order and in two steps.
Main bearings. Stage 1.
22 ft lbs.
Stage 2.
44 ft lbs
Big end bearings.
Stage 1.
11 ft lbs.
Then Rotate bolt head a further by 90 degrees
Head bolt torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
Cylinder head torque is done is steps, if this is not followed you will end up with another leak in a very few 1000 miles. Here is the procedure:
Step 1. Tighten all 10 bolts in sequence to 14 ft/lbs (20 Nm). Step 2. Tighten all 10 bolts in sequence to 36 ft/lbs (49 Nm). Step 3. Tighten all 10 bolts in sequence to 49 ft/lbs (67 Nm).
Step 4. Tighten bolts 1 and 2 to 49 ft/lbs (67 Nm) again.
Install the cylinder head and bolts. The threads of bolt No. 11 must be coated with Loctite® 592 sealant before installation. Tighten the bolts in 3 steps, using the correct sequence:
Tighten all bolts to 22 ft. lbs. (30 Nm).
Tighten all bolts to 45 ft. lbs. (61 Nm).
Retighten all bolts to 45 ft. lbs. (61 Nm).
Tighten bolts 1 through 10 in sequence to 110 ft. lbs. (150 Nm).
Tighten bolt 11 to 100 ft. lbs. (136 Nm)
Tighten bolts 12 through 14 to 110 ft. lbs. (150 Nm)
Torque settings are 110 ft LBS for nine of the ten bolts one bolt is 100 ft LBS /#1 Tighten all bolts in sequence 1 to 10 at 22 ft LBS #2 tighten all bolts 1 to 10 at 45 ft LBS #3 tighten all bolts 1 to 6 at 110 ft LBS #4 bolt #7 at 100 ft LBS #5 BOLT 8 TO 10 AT 110 FT LBS . HEAD TIGHTEN SEQUENCE - standing at front of car bolts down left side are 8/4/1/5/9 bolts down right side are 7/3/2/6/10. left side meaning distributor side.
1978 - 1980 FORD FESTIVA 1.6L65-70 Foot pounds (Final torque) Torque sequence 9 3 1 5 7 8 6 2 4 10 Step 1: torque to 5 Ft/Lbs Step 2: torque to 20-30 Ft/Lbs Step 3: torque to 50-55 Ft/Lbs Step 4: torque to 65-70 Ft/Lbs Recheck final torque in sequence 1988 - 1993 F0RD FESTIVA 1.3L Torque sequence front of engine 8 4 1 5 9 7 3 2 6 10 Step 1: torque to 35-40 Ft/Lbs Step 2: torque to 56-60 Ft/Lbs Recheck final torque in sequence 2011 FORD FESTIVA 1.6L NO TORQUE SPECS AVAILABLETHERE IS NO FORD FESTIVA MANUFACTURED IN 1998 ALSO NO FORD FESTIVA MANUFACTURED WITH A 1.5L ENGINE HOPE THIS HELPS YOU
① Step 1: 22 ft. lbs.
Step 2: 59 ft. lbs.
Step 3: Loosen completely then retorque to 22 ft. lbs.
Step 4: 18-25 ft. lbs.
Step 5: Plus 86-91 degrees
② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
③ The cylinder heads and the lower intake manifold are installed together
Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
Step 2: Tighten the cylinder head bolts to 43 ft. lbs.
Step 3: Loosen the cylinder head bolts completely
Step 4: Tighten the cylinder head bolts to 84 inch lbs.
Step 5: Tighten the intake manifold fasteners to 35 inch lbs.
Step 6: Tighten the intake manifold fasteners to 13 ft. lbs.
Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs.
Step 8: Loosen all intake manifold fasteners completely
Step 9: Tighten the cylinder head bolts to 22 ft. lbs.
Step 10: Tighten the cylinder head bolts 60-65 degrees
Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs.
Step 12: Tighten the intake manifold fasteners to 35 inch lbs.
Step 13: Tighten the intake manifold fasteners to 78 inch lbs.
Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs.
④ 10-12 ft. lbs. +60-65 degrees
⑤ Step 1: 72 ft. lbs.
Step 2: loosen completely to 0 ft. lbs.
Step 3: 29 ft. lbs.
Step 4: Plus 75 degrees clockwise
Step 5: Plus 75 degrees clockwise
⑥ Step 1: bolts 11-22 19 ft. lbs.
Step 2: bolts 1-10 29 ft. lbs.
Step 3: bolts 1-10 Plus 60-65 degrees
⑦ Step 1: 20 ft. lbs.
Step 2: loosen to 0 ft. lbs.
Step 3: 14 ft. lbs.
Step 4: Plus 85-95 degrees
⑧ Step 1: 31 ft. lbs.
Step 2: Plus 60 degrees
⑨ 83 inch lbs.
⑩ Stud bolt: 11 ft. lbs.
Nuts: 31 ft. lbs.
⑪ Step 1: 72 ft. lbs.
Step 3: 29 ft. lbs.
Step 4: Plus 90 degrees clockwise
Step 5: Plus 90 degrees clockwise
⑫ Bolts: 17-24 (M8) 16 ft. lbs.
Install rear main seal
Bolts: 1-16 (M10) 26 ft. lbs.
Bolts: 1-16 (M10) Plus 90 degrees clockwise
⑬ Step 1: 33 ft. lbs.
Step 2: Plus 84-90 degrees clockwise
⑭ Intake manifold collector:
Bolts and nuts: 8 ft. lbs.
Stud bolts: 61 inch lbs.
⑮ Intake manifold:
Bolts and nuts: 5 ft. lbs. and
than to 21 ft. lbs.
Studs: 8 ft. lbs.
