Question about Cycling
Stiletto fork installation
Recently purchased a Giant Stiletto.We had to remove the fork to fit it in my car.What I need to know is in what order do the shims,spacers,bearings,etc.are reinstalled,top and bottom.Is there somewhere I can get a diagram on line? Thank you.
    President:
  • 1,138 Answers
Try http://www.webmountainbike.com/headset1.html Its a good place to start.
Posted on Jul 17, 2009
I have a very nice 2006 rincon but the wheels r shot. Cant afford new wheels but found a 1993 rincon, different wheels but can i use them instead on my 2006? they are free!!
if they will fit between the forks, and the back chainstays... and the brakes can be adjusted to fit the rims...yes why not
Jun 30, 2013 | Giant Rincon
What is the firing order on a 1983 Honda Nighthawk 650?
Instructions
    • 1 Remove the front tire with the crescent wrench and set aside. Remove the nut and axle bolt from the tier and use the hammer to remove the axle bolt from the forks.
    • 2 Remove the securing bolt at the top of the fork on the handle bars. Slide the forks out of the fittings.
    • 3 Place the forks into the oil pan, bottom down, and remove the oil nut. Let the forks drain for ten minutes into the oil pan.
    • 4 Tighten the oil nuts and remove the seal from the fork fitting with a screwdriver. Slide the seal off the fork.
    • 5 Apply oil around the inside of the seal. Slide the seal onto the fork and press into the fitting tightly.
    • 6 Replace the oil in the fork following the manufacturer's recommendation.
    • 7 Replace the forks and the tire following the steps above in reverse order.
Jan 17, 2013 | Motorcycles
Hi Can I fit disc brakes to my sones Giant MTX 225?
Not unless you see the tabs required to mount traditional standardized disc brakes on the fork and left seat stay.
Converting this bike to disc will cost you more than the bike is worth. Get a bike with disc on it.
http://www.youtube.com/watch?v=7Dus9jGmGLI
There are some schemes for adding disc to non-disc-compatible frames but they're Rube Goldberg solutions. And you still need to get new wheels and new brake levers if you're going with hydraulics.
http://answers.yahoo.com/question/index?qid=20081220203159AAUvKFx
Apr 22, 2011 | Giant MTX 225
I'm considering purchasing a Sirius Stiletto 2 Satellite Radio Receiver - just wondering if it can it be connected to my new Harmon Kardon 3600 avr or do I need to buy the Sirius connect SCH1 Home...
You will need to use the aux input from the top of the unit, or from the back of your home dock. If your receiver has a built in or add-on dock for the XM2GO line of radios, you will need to read here: http://www.digitalradiocentral.com/sirius-backstage/stiletto/108379-i-converted-xm2go-dock-stiletto.html
Jan 08, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
Will the Sirus Stiletto II radio work with an earlier Stiletto dock, either auto or home?
no. stiletto 2 will not fit into earlier model stiletto dock. i order the older model boom box by accident. i tried but will not fit.
Sep 18, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
My front fork seals need replacing on my 2005 model TE450, i don't know the specifications, and exactly how much oil to use in each fork
forks need to be removed,and disasemble,and cleaned,new fork seals,reasembleb fit new seals, refit damping cartridge,fill fork with 5w fork oil upto 120mm from top,refit spring, refit fork cap
Aug 14, 2010 | Husqvarna TE 450 Motorcycles
Need to put oil in forks of a 1985 yamaha xj 700
Should be drain screws at the bottom, close to the axel shaft, and one giant bolt on the top of the fork where it comes out of the triple clamp. Remove the lower to drain, replace it. Refill by removing the upper. If I recall correctly, it wants 250ml of fork oil (typically a special 5w oil you need to buy at a motorcycle shop DO NOT USE ENGINE OIL!)
Oct 29, 2009 | 1985 Yamaha XJ 700 X Maxim
Frozen allen bolt above the head lamp - 2002 Vulcan 1500 FI
spray with wd40 let sit 5 min and try if still froze try again
Mar 17, 2009 | 2002 kawasaki VN 1500 Vulcan Classic
How do i dismantle front forks to replace the oil seals
You just needed to.... remove front wheel, support bike on something, undo retaining bolts on forks, tap out fork legs from the top, using a soft mallet. Take out fork seals with a seal pick, (halfords) Replace old seal with new seals, in reverse order) sliding over the fork leg, tapping into place. Then put replace forks etc in reverse order (from dissassembly). Hope this helps
Feb 21, 2009 | 1992 Honda CB 750F2 Seven Fifty
Stiletto 100 sound only comes out of 1 channel
The "one earphone only" problem is common to many Mp3 players. It is not fixable, and the entire player must be replaced. Attempting to replace the headphone jack and assicated circuit yourself can cause major damage to your player. I know you don't like this answer, but it is the only honest answer.
May 07, 2008 | Sirius STILETTO 100 MP3 Player
Cycling Logo
70 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
