Question about Canon PIXMA MX310 All-In-One Printer
Recommend new C-CRT" appears on the LCD i can't find in the guide
    President:
  • 2,306 Answers
C-crt, refers to the cyan ink cartridge. It's telling you it's almost out of cyan ink...
Posted on Jul 16, 2009
I need an update for a 18.5 lcd tv.model no:19-229 I can find it anywere...thank u
Howdy James Andrew,
Appears to be a UK
Tesco Technika ... This is a (mostly) USA site
So our cyber-wisdom gets a little sparse on UK "updates"...
(but we try).
(so... "retuning info... UPDATE": is what U're after??).
Try these sites below...!!
SERIOUSLY ...
a local search ought to work better for YOU.
Good luck...!!
TESCO LCD- 19-229 USER MANUAL Pdf Download. - ManualsLib www.manualslib.com/manual/723669/Tesco-Lcd-19-229.html
Page 1: User Guide. HD Ready LCD TV with Freeview, DVD Player & USB Media Player User Guide Model No LCD- 19-229.
2 Retune How to retune. Retuning your TV is a very quick and simple process. We recommend that you retune every few months to ensure you are receiving the very latest TV and radio channels that are broadcast. 1) On the remote control press [MENU] followed by 8 - 8 - 8 - 8 (so the number 8 button four times) 2) The First Time Installation menu will appear. Press [OK] and tuning will take place. For help and support regarding the digital switchover, please contact Digital UK: Telephone: 08456 50 50 50 (calls charged at local call rate, approx 3p per minute daytime or 1p per minute evenings from a BT landline) Digital UK website: www.digitaluk.co.uk
Digital UK Home
Carnac the Magnificent
Feb 05, 2017 | Televison & Video
Tv will not turn on green light flashes for 10 seconds then goes to red
Tv's are designed to check themselves for problems when 1st turned on. If something is shorted and a voltage goes to high they will not turn on fully. It sounds like your set is trying to turn on yet sees a problem then goes back into standby mode. This can be cause by many different circuit problems. Generally repairs can range from $75 to over $200 depending on problem and brand. I only recommend repairs if half the cost or less to fix. Since your ? only stated it's a CRT. I would recommend your purchase a new LED LCD TV. CRT (cathode ray tube) Tv's are now old technology. You could probally find a new set for the price to fix the old.
Jan 20, 2014 | Televison & Video
I get green curve lines and some flashing green light
Most likely it is the green CRT that is failing. Unfortunately Sony does not support these models much anymore. What they require is to send the CRT with the Optic Coupler to them so they can mount a new green CRT to the Coupler then send it back to you. For the cost and time it takes to do this I recommend you replace the set with a LCD, LED, flat screen set.
I hope this helps,
Skyassoc
Dec 10, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
"Recommend New C-CRT" appears on menu screen ????
I would guess at:
"Recommend new Cyan Cartridge"
Cyan is the blue one.
Please rate me if you found this helpful.  Thanks.
Mar 06, 2010 | Canon PIXMA MX310 All-In-One Printer
"Recommend new C-CRT" appears on the LCD
C-CRT means to replace color ink cart. because it is low on ink or is out.
B-CRT means the same thing, but regards to the black ink cart.
Press menu button, then go to fax settings, then go to memory reference. Then go to memory list, and hit OK...this will give you a list of everything stored in memory. Then to print each document in the memory, go to print document in the memory reference submenu. Then enter the TX/RX No listed on the memory list.
if that doesnt help.... contact canon at the earliest.....
thank you for using fixya...
have a nice day
Jul 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Problem with faxing
Goi to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
put "recommend a new c-crt" in the question box. Select the ERROR LCD: RECOMMEND NEW C-CRT answer and follow the instructions to clear the cyan cartridge error. This should take care of the problem. Let me know if this doesn't work. Thanks.
May 08, 2009 | Canon PIXMA MX310 All-In-One Printer
I have the canon mx310. cannot print out what is in the memory. it reads new B-CRT AND C-CRT
the message - recommend new: C-CRT means it needs a new colour toner cartridge and recommend new: B-CRT means it needs a new Black Cartridge.
Oct 01, 2008 | Office Equipment & Supplies
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Canon PIXMA MX310 All-In-One Printer Logo
504 people viewed this question
old marine
old marine
