Question about Minolta magicolor 2300W Laser Printer
The printer jams often and often makes beautiful fans out of the paper you can contact me at yak1racs@yahoo.com
    Scholar:
  • 50 Answers
You probably have a piece of paper from a previous jam stuck in the printer. If it is making beautiful fans, then it is probably in the fuser module. (At least in my experience.)
I'm not sure about the minolta, but most printers have color coded levers inside that you need to open to check for paper jams. In HP's they are green.
Posted on Jul 16, 2009
How to clear paper jammed on printer mx318
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam. ...solve other printer problem
Sep 18, 2012 | Canon PIXMA MX310 All-In-One Printer
Epson stylus photo px660 with a paper jam error after dismantling it displays a printer error with all lights flashing
Paper jam problems can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
you can try following points.......
1.turn off the machine for at least 5 minutes and disconnect the interface cable to the computer.
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
**You will need to try this several times to get the sequence correctly.
If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Sep 11, 2012 | Epson Office Equipment & Supplies
Paper jam
Sep 04, 2012 | Canon PIXMA MP150 All-In-One InkJet...
My HP DeskJet is jammed how can i remove the jam and print
Paper jam is very common problems for all printer . It can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
***You can also solve the common printer problems....read more
Aug 29, 2012 | Office Equipment & Supplies
I am using canon 2900 printer and i having every time paper jam issue please help me
Aug 27, 2012 | Canon LASER SHOT LBP-2900 Printer
Pro915
There are a number of conditions that can cause paper jams. First, check the condition of the paper. You should use only clean, undamaged paper designed for inkjet printers. Remove the paper and fan the edge to make sure it is not sticking together.
Next, make sure that the paper is properly loaded. The edge guides should be snug against the paper without causing it to buckle. Do not force paper into the printer.
Finally, check that there are no obstructions in the paper path. Use a flashlight to look into the printer.
If you're still having problem please contact us at LxkListens@Lexmark.com or http://bit.ly/boldchat.
Aug 17, 2012 | Lexmark Pro915 Wireless All-in-One Inkjet...
Lexmark X544 continually jams paper.
Please make sure that the paper settings on the printer is in sync form the application (e.g Microsoft word), Make sure the output or mailbox option is aligned correctly with the printer. If there is any slight angle between the printer and the option, it can cause the paper to jam in the option, check the condition of the paper.
You should use only clean, undamaged paper designed for laser printers. Remove the paper and fan the edge to make sure it is not sticking together.
If you need further assistance you may contact Lexmark Technical Support Center.
Sep 12, 2011 | Lexmark X544dn All-In-One Laser Printer
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
The readout says Paper Jam, open front cover to clear, press i. There was no jam. A page exiting the printer stuck at the bottom end. I pulled it out easily and intact. Immediately, the red light went...
open the printer again.you didnot specify which kodak printer you have. take all papers out of paper tray .fan them properly to make sure that no two papers are sticking to each other. load papers again in to the printer,contact kodak @1800 421 6699 if u face problem again.
Jul 25, 2009 | Office Equipment & Supplies
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Minolta magicolor 2300W Laser Printer Logo
201 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
