Question about Nakajima AE-710 Typewriter
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
    President:
  • 566 Answers
In case you need you it, for future reference, you can download the Operation Instructions for your IBM SELECTRIC II Typewriter from here::
http://files.getdropbox.com/u/1322442/IBM%20SELECTRIC%20II%20Typewriter%20-%20%20Operating%20Instructions.pdf
Posted on Jul 22, 2009
    Problem Solver:
  • 6 Answers
Space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Posted on Jul 16, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
How do I remove and replace the tab set/clear button on an IBM correcting selectric II typewriter
Yes, all the keys are snap on. Use a spring hook on top and bottom of the key and wiggle (carefully) upwards to remove. (If you don't have spring hooks, then hefty paper clips will do. Create a 90 degree or better bend on the end of the clip)
Nov 27, 2014 | IBM Correcting Selectric II
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Nakajima AE-710 Typewriter Logo
216 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
