Question about LG HBS-110 Wireless Headset
How do I put the lg hbs-110 into pairing mode?
YOU TURN THE POWER ON THEN HOLD IN THE SILVER PAUSE, PLAY BUTTON UNTIL IT SELECTS THE PAIRING MODE.
Posted on Oct 06, 2009
  • Hitone1 Mar 24, 2011
    Just found my old LG HBS-110 Head set. Tried a couple of other suggestions on different web sites. They failed. However, as suggested by KENBBQ1 to hold in the silver pause/play button until it selects the pairing mode, my headset began to work properly. Thank you very much!
    Problem Solver:
  • 6 Answers
Ask you mom
Posted on May 04, 2010
I have misplaced the manual for my lg tone platinum i cant remember what to do on the headset to pair it to my phone. cant you assist?
You can find the manuals here:
http://www.lg.com/us/lgeai/Manuals
Just put in your model number. But to pair a device to your headset, you can do the following:
1) Easy Pairing a) Move the Power Switch to the "ON" position. b) If it is your first time paring the device it will automatically enter pairing mode. If it has been paired but no paired device is in range it will enter Pairing mode after 10 seconds.
• The LED indicator will be Solid Blue c) On the device you wish to pair, find the bluetooth menu and "serch for" or "add" new devices d) Select "LG HBS-700" From the list of devices e) If asked for a Pass/Pin Code enter 0000 (4 Zero's) f) Once pairing is complete you will hear a beep • The HBS-700 will automatically turn off if not paired within 3 minutes.
I hope the information posted helps!
Jun 08, 2016 | LG Radio Communications
What is the pass key code to pair lg tone pro HBS 750 to my ps3?
1. You need to charge your headset to full capacity using the charger supplied with it.
2. Disconnect it i.e. your headset from the charging source.
3. Press and hold the "Call/Send" button located on the front of the headset for like 5 seconds to activate pairing mode.
4. You should notice an indicator light begin to flash. Your headset is in pairing mode already.
5. By now, you must have had the bluetooth on your PS3 on.
6. Have both devices pair with each other.
LG headsets use a pairing passkey of four zeros ("0000").
Apr 15, 2015 | LG Electronics HBS-750 TONE PRO Wireless...
How do i put lg hbs-700 into pairing mode
I had the same issue, fixed by using the Manual mode for pairing. From the manual:
2) Manual Pairing (Pairing with another phone or re-pairing)
a) With the Power off, press the CALL button and move the power switch to the
'ON' position at the same time for 4 seconds.
b) When the headset enters Pairing Mode, the LED indicator will show a solid
blue light. After the procedure repeat Easy Pairing steps c through f.
Steps C through F are to go to the bluetooth settings area and manually select the HBS-700 for pairing.
Mar 14, 2015 | Home
How do i get the lg hbs 700 bluetooth headset to go into pairing mode.???
The LG HBS 700 will automatically go into pairing mode if it does not detect the last device it was paired with. So, make sure all other bluetooth devices are off, turn the earpiece on and wait for the status light to show solid blue. Then you can turn on the bluetooth on your other device and search for the HBS 700.
May 17, 2014 | LG HBS-700 Bluetooth Headset
How do i put my lg hbs-730 into pairing mode
It should automatically go into pairing mode if it does not detect the last device you paired it to when you turn it on. After startup it should say "ready to pair". Make sure all other bluetooth devices are turned off before turning on the HBS730
Feb 02, 2013 | LG HBS-700 Bluetooth Headset
How do I put LG HBS 700 into pairing mode
Turn off the headset. Keep the Call button pressed, turn the headset on and wait for the 3 bips (~4 seconds after turning it on). Then release the Call button. The solid blue light will indicate the pairing/discovey mode.
Apr 21, 2012 | LG HBS-700 Bluetooth Headset
Cant get LG HBS-250 into pairing mode
Make sure the headset is off when you hold the call button for 5 sec. And don't stop holding it when you hear/see something happen after the first 2 sec. Keep holding it for the full 5 sec. The blue light will become solid which means it's in pairing mode.
Dec 04, 2009 | LG HBS-200 Bluetooth Headset
LG HBS-200 Bluetooth Stereo Headset user manual instructions needed to pair with blackberry
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
User Manual
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device,
then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Aug 30, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
How to use / user manuel info
The HBS110 is a bluetooth headset. To pair it with your phone, first turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device. When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Hope that helps,
Sai.
Mar 16, 2009 | LG HBS-110 Wireless Headset
LG HBS-110 Wireless Headset Logo
311 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
