Question about Weiser Lock POWERBOLT ELEC DEADBOLT
How do I wipe out the existing code on my lock and enter a new one?
    President:
  • 704 Answers
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you want to reset your master code which will clear any other codes as well. You can then enter in all new codes to operate your lock.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
  • xgenx Jan 09, 2011
    the manual does not advise how to change the mastercode or reset to factory settings.
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
How do you delete existing codes to put in a new code?
you dont need to delete them they are replaced whern you enter a new code.
SET ..BTN and object TV1 or VCR1 etc light becomes steady on remote Enter code eg: 291 light goes out PRESS SET and try.
Please rate my help++++Thanks for using FIXYA
May 07, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
The phone is locked to tmoble and i have an at&t sim card. how do i unlock the phone?
If it is a network lock you need to contact you're service provider for the unlock code.
If it is a key pad lock kindly enter wrong password for 10 time's you're handheld will get wiped. Then it will ask for the reset password enter the new password and remember that. (No data will be available when your Handheld is wiped)
Nov 06, 2009 | RIM BlackBerry Pearl 8100
How to unlock blackberry 8310
If it is a Network unlock code you need to contact you're service provider.
If it is a Keypad lock enter wrong password for 10 time's, Your Handheld will get wiped out and it will ask for the reset password enter the new password and remember that. (In this procedure you're DATA will be wiped out no DATA will be available in your Handheld)
Nov 03, 2009 | RIM BlackBerry Pearl 8100
I have locked keypade of blackberry 8100, how can i unlock while i forgot the code
If it is a keypad unlock code kindly enter wrong password for 10 time's you're Handheld will get wiped off. Then it will ask for reset password, Enter the new password and remember that.
NOTE:- No data will be available when your Handheld is wiped off.
Oct 18, 2009 | RIM BlackBerry Pearl 8100
Keypad is locked
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
Aug 01, 2009 | RIM BlackBerry 8700c Cellular Phone
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
649 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
