Question about Hayward Comfort Zone Electric Spa Heater 11kw
Burner goes on and off
I have a rather old comfortzone heater is it normal for the burner to kick off and on about every five minutes ,even with the thermostat turned all the way up?
    President:
  • Hayward Master
  • 1,378 Answers
No, it is not.
Posted on Jul 17, 2009
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
No Burner Light?
check ignitor if ok check gas
Oct 18, 2017 | Noritz Water Heaters
A friend gave me a Hayward Comfortzone pool heater several years ago, I have not used it yet but might, wondering how I could get a manual for installation and hook up etc.
Hayward no longer offer parts or any other support for the old Comfortzone heaters but you can follow the general guidlines from any of the Hayward heaters as far as gas line sizing, spacing requirements and piping. This one on the H-Series should work...
https://www.hayward-pool.com/pdf/manuals/Manual285.pdf
John
May 15, 2011 | Hayward Pool & Spa
I have the Comfortzone Infrared heater. The heating unit will not kick on. It tries to but then a code comes up that looks like AOS or AO5.
sounds like the outlet is not enough power for the heater. Remember with an electric heater youre dealing with watts and amps, It should be plugged into its own dedicated service for proper operating.
Mar 04, 2011 | Heating & Cooling
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
Heater wont stay on. HELP!
Have the Hayward guys come out and prove to you that it is indeed low pressure and then get an estimate for repair costs. Assuming there is no warranty in effect, you might want to locate the heater manufacturer for guidance. They may have a website that may be of help.
Mar 20, 2017 | Hayward Comfort Zone Electric Spa Heater...
Central heater kicks off and on constantly
It is a strong possibility the flame sensing electronic thermocouple has become contaminated. Buildup on it causes malfuctioning like you described. To remedy it you simple remove the flame sensor and clean it with steel wool. here is a video I found on line:
Furnace cycling frequently
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Hayward Comfort Zone Electric Spa Heater 11kw Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
