Usually worn parts in the gearbox, called 'detents'. These normally hold the gear engaged. Try holding it in gear with the lever. If that does not work then the wear may be further in, on the shaft spacers and gear teeth themselves. You may be able to get a reconditioned gearbox, depending on where you are.
Another cause mentioned by owners is worn engine mounts, so check those too.
SOURCE: 1997 Toyota Land Cruiser rain water leak
check the sunroof drains,they may be clogged they are located on the right and left front of the sunroof.
SOURCE: quantity of engine oil used in 1 HD engine toyota land cruiser
if you have just bought the car change the oil and the filters asap on the grounds that the oil and filters may have not been changed for quite a while also change air and fuel filters also and grease any steering and tail shaft joints check brake fluid and water levels also and for any leaks around brakes gearbox and differential then every 5000km change oil and every 10000 change filters and spark plugs start with 4liters of oil let settle check level and keep topping up until close to full mark fill oil slightly under than over too much oil will build up pressure and burst oil seals in motor the more expensive the oil the better the quality its a bit like scotch whiskey best of luck glenn.......
SOURCE: 2004 Toyota Land cruiser key programming
you need to take it to the dealer so they can program the key to the car which requires there software. hope this helps
SOURCE: Toyota Land Cruiser Prado (LC90) Owner's Manual (free download)
i need onwer's manual of toyota prado 2005 3.4L
SOURCE: toyota land cruiser 1997 80 series electrical wiring diagram
what are the colour of the wires for the unlock / lock for the central locking for a toyota landcruiser 1990 modle ?
