Hey Ryan here's a link to your wiring.It tells you the location number. Repair Guides Horn Cigarette Lighter 2005 Horn Cigarette Lighter 2005...
SOURCE: cigarette lighter fuse location
The cigarette fuse is located in the battery junction box under the hood, it is fuse # 10 and is a 20A fuse, open the hood and find the box it is on the passenger side towards the back of the compartment, it is 10th in line on the top row, also you can check these fuses without removing them through the clear plastic top so that should make things a little easier too, hope this helps
SOURCE: Cigarette lighter fuse location on Ford Escort ZX2 2002
I had exactly same problem. I could not use my GPS or charge my cell phone.
In front of the driver sit, there are actually 2 fuse boxes. You probably found the first one. A second one is located above well hidden. Once you find it, you'll find the fuse you are looking for.
SOURCE: fuse for 1999/2000 ford focus diesel estate cigarette lighter
its fuse 46 and it should be a 15 amp according to the manual as i have the same car as you hope this helps
SOURCE: cigarette lighter not working, already changed fuse
Look in your manual for the Power Distribution Box reference in Roadside Emergencies. It should be located under the hood on the driver's side. My 2002 Explorer has two power points on the center console and the 20A fuses in the Power Distribution Box for them are number 7 and number 9. They cost $3.99 each at AutoZone. The cigar lighter fuse under the dash is unrelated.
SOURCE: need to locate fuse for cigarette lighter have no
fuse #46 in the passenger compartment fuse box.
