Question about Minolta Office Equipment & Supplies
Cs pro minolta copier displays a code co6
Cs pro minolta copier displays a code co6 along with a picture of a wrench
  • Minolta Master
  • 6,680 Answers
Open close the front door if that does not work and the code comes back check you scanner cable underneath the large glass for the documents
Posted on Jul 19, 2009
Error code c0510 for a minolta cs pro
Change the fusing unit heatre lamp thermistor,reset the error code.
Jan 22, 2012 | Minolta Office Equipment & Supplies
I have an error code c0994 on my CS PRO EP2050 how do i fix it?
On the control panel screen lower left hand corner see a small wrench touch it will send you to another screen once there open close the front door.
Apr 25, 2011 | Minolta EP4000/5000 CS/PRO Copier
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
Apr 06, 2010 | Minolta EP4000/5000 CS/PRO Copier
C05
Sir to fix will require you to take the rear panel off with the copier on. the upper rear panel once you have it off. Then find the circuit board on it will be a small black button, lower right side. press it. the machine will reset if it comes back your fusing unit (The HOT) part has a bad lamp thermistor, or thermosat. And will need replacing. The code will not clear by powering off then on. or by opening and closing front door.
Mar 10, 2010 | Minolta EP1083 CS/PRO Copier
Both paper cartridges malfunctioning of minolta 4000 (i dont know the solution)
Do you see a small wrench in the bottom left corner of the displa pannel? If so press the wrench and the display will change then open and close the front door and try to open the paper trays. If it dose not work you may have more then a basic problem. Good Luck
Mar 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code problem
CALL THE NEARST DEALER OR GO ONLINE AND TYPE THE MANIFATURE NAME ONLY AND LOOK THREW THE LIST OF SUBJECT AND CLICK ON THAT LINK
ROD
Jan 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
93 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
