Question about Tools & Hardware - Others
Bostitch n80sb 1 framing nail gun shoots 2 nails at a time'' just checking to make sure it is the magazine before I order one
  • 2,176 Answers
I would think a part other than the magazine. I would first check the condition of the nose to make sure it is not just worn out. Also check the driver for the end being flat and the back side (toward nail)not worn excessively and lastly check the O ring on the piston. Starting with nose unplug air and look to see if oval and then bounce the tool without air and see if the piston drops from the rest position. If so that is where I would start. Let me know if something other than this and I will try and help. I have worked on quite a few of these. If I have helped you would you please rate my response accordingly. Thank you
Posted on Jul 16, 2009
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Bostitch N80SB won't reset after firing
Most likely just needs piston oring. Remove nails from the gun and point nose of gun up then down again. If the piston travels up and down in the cylinder, replace the oring. The piston returns to top with air pressure and needs good snug piston oring and good lower bumper (if bumper is cracked or missing pieces ~ replace ). Be sure to lube the orings in the headvalve with silicone paste or white grease. Part # ORK11 oring kit will reseal the gun. Good luck with your repair.
Jun 02, 2012 | Stanley Air Tools & Compressors
I inherited a Bostitch N805B uses 28 degree .113 and came with clipped head nails. Will it shoot full round head nails?
I could only find a Bostitch N80SB full round head nailer in their lineup so I hope that's what you have. No it will not fire full round had nails because they are stacked at a lower angle to accomidate for the full head and material used to hold the strips together. Senco does make a full round head nail that fits their clipped head nailers but it does not list the Bostitch nailers as one they will fit into so I don't know if they will work in your gun. The Senco part number for their three inch, full round head nails for clipped head guns is K527APBK.
Jan 31, 2012 | Tools & Hardware - Others
My N80SB framing nailer won't shoot the new nails (non-clipped head). What do I need to do?
For a visual on what type of nail you should use go here:
http://packagingandfastening.com/air_stick_nails_28_degree_framing.htm
You will find a list of differnet nails sold that will work on your gun. Bostitch is about the only nailer that uses a welded wire strip of nails. Good luck
Oct 25, 2010 | Stanley Bostitch N80sbn80n80c Nailer...
I can get he gun to shoot 1 nail but won't load the next nail?
There is a small piston on the side of the magazine that pushes the feeding claw which pushes the next nail into place. Either the feeding claw or piston is stuck or the piston is worn out and needs to be replaced.
Sep 30, 2010 | Stanley Bostitch Coil Framing Nailer
How do you close the magazine on a bostitch sx150
once the nails are in place, slide the slide forward and you may have to press in the same button you use to open the magazine to get it closed the rest of the way.
Dec 05, 2009 | Stanley Factory Reconditioned Bostitch...
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
try going to their website -I have several guns and each take at least 4 sizes of nails- yours should be no different- good luck hope this helps
Oct 11, 2008 | Stanley Bostitch N86S 1 Factory...
Tools & Hardware - Others Logo
529 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
