Question about Pioneer CDJ-200 CD Player
One of my two CDJ 200s won't turn on 9 times out of 10 and if it does it turns off within 10 minutes at most. It seems more likely to turn on when my cdj, mixer, and stereo are not on. They are supposedly brand new and unopened from eBay and their appearance suggests that they are brand new. On the occasions that it doesn't turn on when the power is switched on it is noticeable that the thin red lines on the display light up, but otherwise nothing else turns on.
    Problem Solver:
  • 11 Answers
This is a problem with the power supply.
Posted on Jul 23, 2009
  • comnieto Dec 20, 2010
    I had the same problem recently, it turned out that there was a problem with the voltage distribution.
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: New pitch Control for pioneer cdj 500 mk 2
Enter your make and model in a search engine like google.
Put "parts" along with your search
Posted on Mar 03, 2009
localwonder
  • 6784 Answers
SOURCE: pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
Posted on May 21, 2009
DJAJ-NE
  • 54 Answers
SOURCE: CDJ 100 s PROBLEM E-9103 and E-7201
E-9103 is MECHANICAL TIME OUT,
Solution : some object in compartment slot, remove it, or clean player compartment
E-7201 is disc cant be read in 20 seconds,
Solution : Disc has scratch, Replace disc
Disc is dirty, Clean disc
Dj ajay
djajay@inbox.com
Posted on Jun 11, 2010
SOURCE: my cdj citronic mpcd-s6 keeps saying disc error
i have the same problem, i do not know how to fix it. i have 2 of them and one plays fine whilst the other does this
Posted on Aug 22, 2010
Key programing toyota 2002
No need to panic rush through this procedure, just do it right. Haste makes waste.
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert an original Master Key into the ignition but do not turn it.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert New Key into ignition but do not turn it.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. Now sit and wait for about one minute until the security light in the center counsel stops blinking and turns off.
8. Remove new key and depress and release brake pedal 1 time.
9. Test your key now. It should work if you followed the instructions. If not, you may want to try the following instructions:
This procedure is for 2002 Camry and most other models in this year of Toyota. In the future always give the model as well as year and make. Thanks
Nov 06, 2016 | Toyota Cars & Trucks
No input level and no audio
The problem is that it may not have 'just' been the fuse that blew. Sometimes, because components are delicate, the fuse blows shortly after the damage has already taken place. My concern is that the logic board has a component(s) fried as a result. The fuse blew only after the fact. Luckily, you did not suffer any damage to your CDJ 200s.
Unfortunately, the cost to fix this situation may be much more than the unit is worth. You're probably looking at having to get another unit to replace it.
Jan 06, 2013 | Behringer Vmx200 DJ Mixer 2 Channels with...
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
1999 CHEVY LUNINA WON'T START BATTERY AND
Check the dash once you turn the key to the run position the passlock runs a security check using a set resistance value through the chip in the key. If the security light begins to flash the reading it received was incorrect or it didn't get a reading at all. You can try reseting the value it is looking for by turning the key to start then releasing it. After 10 minutes turn it off then cycle it start again leaving it in on for 10 minutes then back to off then one more time. After the third cycle has completed for a total of 30 minutes. You should be able to turn the key on and start the vehicle. If the light continues to flash their is a problem with the chip in the key or the connections within the ignition its self. Both are common but a Pass Lock Relearn as described above will usually adapt to the poor connection values. Hope this helps.
Aug 28, 2011 | 1999 Chevrolet Lumina
I need to program a new fob. am reusing the old key! can you help?
  1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
  2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  3. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  4. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp 3 times.
  5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
  6. Turn the ignition to OFF and remove the key from the ignition switch.
  7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
Mar 30, 2011 | 2006 Pontiac GTO
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
Round lcd?
Unfortinetly i cant recommend to you a quick fix or a quick check as the fault seems to be intermittent,
i would suggest taking the player to your cdj pioneer dealer.
email: info@audiovisualservices.info for all your dj equipment repairs.
Thanks.
Aug 16, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-200 CD Player Logo
552 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
