posted by fixyajeremey on Nov 18, 2007
Over the range LG LMVM2055SB microwave keys are not responding. I turned the electrical power off/on, pressed the start-lock more than 1min, microwave does not start. Only keys responding are number keys 1 & 2. The vent fan speed key used to respond, now it works only upto speed 3.
This seems to be happening after our latest cleaning. After cleaning, it worked OK once, then displayed locked. The locked sign went away. But now, no matter, what we do, we cannot start this microwave.
This is about 2 years old.
Thank you.
Jeremey
Comment by fixyajeremey, posted on Nov 18, 2007
We are not really sure, we think the cleaning lady might have used SoftScrub liquid gel.
How to replace the keypad membrane switch? Is it too difficult? Does it involve dismatling the door or something?
Thank you.
Thank you.
Best Solution
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Comment by MicrowaveSvc, posted on Nov 18, 2007
Generally you unplug it, remove the screws in the grille to remove that, remove the screw in the top of the control panel frame, then lift up and out on the frame to ease it away from the chassis of the oven part way.
You will then be able to mark and/or photograph the wires so that you get each of them back where they should go. This is important.
Now the control panel assembly can be separated from the chassis.
Unlock and disconnect the green plastic strip - the part of the keypad that plugs into the circuit board.
Next, peel the old keypad off the frame, clean all the residue with Goo Gone, lighter fluid, or another solvent, clean it squeaky clean, the peel the backing off the new keypad and stick it on.
The reassembly is the reverse of the the disassembly.
We actually have the entire service manual for this one at our Web site: http://www.microwavedisplay.com/LMVM2055_Service_Manual.pdf
For future reference, I always recommend that users spray cleaner on a soft cloth then wipe the control panel.
And I always recommend non-ammonia cleaners since they can crack and damage plastic.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE JVM1650 1000 Watts Microwave Oven
GE JVM2070 1100 Watts Microwave Oven
GE JVM3670 1100 Watts Microwave Oven
GE JVM1430 950 Watts Microwave Oven
GE JES636WK 700 Watts Microwave Oven
GE JES738 700 Watts Microwave Oven
GE JES1289SK Stainless Steel 1000 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Kenmore 62702 / 62709 950 Watts Microwave...
can't figure out what wrong
We have a Kenmore microwave... Answer This...
Whirlpool MH1170XS 1000 Watts Microwave Oven
Whirlpool microwave MH1170xsy0...
Microwave does not heat. Turn... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
