Question about Plextor PX-708A DVD±RW Burner
The plextor dvdr px 708a stopped working
The plextor dvdr px 708a all of a sudden is no longer recognized in my system. It says i have to reinstall... I didn't change anything from the computer! HELP!
  • 696 Answers
Thanks for coming to FixYa, The problem you have is either a well documented software problem, corrupted plextor software or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then try re-installing the plextor software. Again if that doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
I can't read or write with my PLEXTOR DVDR PX-716A (DVD+R9) why ?
drivers, bad dvd, or the dvd player is bad, and possibly the usb to your computer 1.0, 2.0, 3.0
May 27, 2010 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
Plextor px-708a will not recognize disks. Just removed a second DVD drive from the system and jumpered px-708a as MASTER. The system recognizes the drive; it just will not read.
as you've changed the configuration of the drive from slave to master you need to go into the bois and change the settings for the drive so that it reads the px as master cd drive
Feb 25, 2010 | Plextor PX-708A DVD±RW Burner
My PLEXTOR DVDR PX-708A DOESN'T RECOGNIZE CD.
Go to Plextor.com and download the firmware update. If you have the 708A-UF model, make sure you install the firmware update using a USB cable. Using a firewire cable to do the update can cause a data corruption problem with the firmware update.
Feb 17, 2010 | Plextor PX-708A DVD±RW Burner
My HP computer does not recognize the Plextor PX-880U DVD Drive
Try getting new firmware from Plextor and see if that doesn't help the problem.
Feb 06, 2010 | Plextor (PXW5224TAT3BP10PK)...
PX-708A Drive not working
This drive does not have power. First open the case and check power cable to make sure it is properly seated. If your power supply has additional power connections of that type, try swapping them (it is a 4 pin molex connector used for IDE hard drives and CD drives). You might want to use a multimeter to check the power output on those connectors.
If the power supply is providing sufficient power and properly seated, it could be the drive itself has failed. (The power is not getting past some part in the drive. I do not do CD drive disassembly so I don't know if there is a fuse or some ofher component that you should look for having been damaged.) With IDE DVD-R/W devices being available for $30 or less, it isn't worth the time to search. Replacing it with a new one is simple.
I hope this helps.
Jan 25, 2010 | Plextor PX-708A DVD±RW Burner
I get kicked off line whenever I open either one of my optical drives.
try updating the drivers.if you cant just uninstall them and reboot the computer.Windows will find new hardware and reinstall the drivers.
good luck
Sep 14, 2009 | Plextor PX-708A DVD±RW Burner
Having problems
it might be damaged.
actually i think it is and maybe you can try replacing it. if you want to try a fix let me know
Oct 30, 2007 | Plextor PX-708A DVD±RW Burner
New problem old hardware
Right click my computer>properties>hardware>device manager>right click on your burner drive>properties>driver>uninstall. Go back to the device managger window, click on "action" and then on "Scan for hardware changes".Windows should recognize your DVD device by announce you about a "new hardware". In case it will happen and the problem will still exist : - Use a laser lens cleaner CD - Open your PC and check whether all connections to CD are OK (flat cable,power cable,Master/Slave jumper). Let me know with your results. Good luck !!!
May 29, 2006 | Plextor PX-708A DVD±RW Burner
Plextor PX-708A DVD±RW Burner Logo
1,084 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
xkikbxr
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
