Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Grey Screen with 480p signals (or higher)
The manual states that the TV can support signals of 1080i, 720p, 480p and 480i, but when I select this format (with my Nintendo Wii or Sony PS3) the screen turns to greyscale.
Any thoughts?
Re: Grey Screen with 480p signals (or higher)
I've had a KP 53HS10 for close to 8 years I think. 4 years ago the picture started blinking after long use, then more and more often. I had a repairman come and replace the tuner card (that's all I know about what he did). Now that I finally have HD from cable, I've found that 720 doesn't work and 1080i works, but the picture blinks on and off apparently struggling with some inner problems. Everything looks great, for a second and then it blinks. The red light blinks 5 times repeatedly while this is going on. I called SONY 5 times means get a repair man. I searching forms like this for help as well.
Posted on May 13, 2008
0 characters
3 Points
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
I have Hitachi CMT 2928FX, I am using AV input 1 on back, great sound, black and white picture that is just out of synch. I do not have the Hitachi remote, I am using the programable remote from DISH TV. I...
May be one of two things. With a standard av input (called Composite Video and usually colored Yellow) then the signal must be 480i, Standard Definition with (i)nterlace. If it is higher, say 1080i (another interlace signal but High Definition), 480p (Standard Definition in (p)rogressive mode), or 720p (another HD in progressive).
Try reseting the Dish receiver by unplugging it for 15 seconds.
Aug 18, 2008 | Hitachi Projection Televisions
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Samsung 52 inch dlp tv purchased in 2003 will not handle 1080i signal from brighthouse hddvr. states no signal detected thanks howard
    Be sure you are using the correct component input
    This model has three component inputs and only one (the third from left) will work on 1080i signal the first two only handle 480i and 480p
    This tv will not operate with 720p signal
    Jun 17, 2008 | Projection Televisions
    I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
    There could be a problem, but verify the settings as listed in the owner's manual as follows:
    1 Press the MENU button to display the menu.
    Press the ▲ or ▼ button to select Picture, then press the ENTER button.
    2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
    3 Press the ▲ or ▼ button to select the screen format you want.
    Press the ENTER button.
    Press the EXIT button to exit.
    16:9 : Sets the picture to 16:9 wide mode.
    Zoom1 : Magnifies the size of the picture on the screen.
    Zoom2 : Expands the Zoom1 format picture.
    Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
    4:3 : Sets the picture to 4:3 normal mode.
    Just Scan : Use this function to see the full image without any cutoff when DTV
    or HDMI 720p/1080i signals are input.
    Press the P.SIZE button on the remote control to change the picture size.
    And realize the restrictions as listed:
    • In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
    modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
    • In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
    Wide Fit can be selected.
    • In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
    screen by pressing the ▲ or ▼ button.
    •You can not change the picture size when PIP is set to Double.
    •When Double ( , ) mode has been set in PIP, the Picture Size cannot
    be set.
    •Wide Fit can be used when watching a Digital HD (High Definition) signal.
    Wide Fit sets the optimum picture format by expanding it both horizontally and
    vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
    does not support all external devices (DVD, VCR etc.).
    Keep us posted.
    May 29, 2008 | Samsung Projection Televisions
    Mitsubishi WD-62525 Input 480i
    it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
    Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
    High Def.
    If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
    Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
    Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
    109 people viewed this question
    Top Sony Projection Televisions Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Jason Harris
    Jason Harris
    Are you a Sony Projection Television Expert? Answer questions, earn points and help others
