Question about Brother MFC-8460N All-In-One Printer
I had computer problems today and had to swop my hard disk into another computer box. After doing that my Brother MFC8460N faxed and copied but does not want to print from my computer at all. I uninstalled the printer via the download and re-install it. Still no you. As I reach the point in the installation where it says plug the USB cable in and put printer on, the computer does not see the printer and does not move on.
    Brigadier General:
  • 10,406 Answers
Trying connecting the USB printer to some other computer,
to see if the other computer recognizes the printer.
Try a different USB port on your computer.
Try a different USB-device (memory-stick? camera?) into your USB port, to confirm that the USB-port is working.
Posted on Jul 16, 2009
We have a Brothers MFC8460N Fax Machine. We are able to send faxes butwe can not receive faxes. What could the problem be?
Make sure the machine is in the "fax" mode and has not been switched to "tel" mode.
Try calling your fax machine from a telephone and see if it answers...you should hear the "chirps" in the telephone headset. If your machine dosn't answer do you get busy signal, beeps, what ????
Nov 16, 2010 | Brother Office Equipment & Supplies
Need to add mfc8460N to computer, don't have disk
What is the windows OS of the computer? you can try this link
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc8460n_all
Oct 03, 2010 | Brother MFC-8460N All-In-One Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
On my Brother 4100 Fax machine, there is an absence of reproduction from top to bottom in the middle on copies only. Printing from the computer is okay.
Replace the copy element inside will shore this up the element is the OCR sensor once that is replaced things should be as normal and brother would carry the part. Otherwise there is not much else that can be done in this case, Thanks for using fixya.com please od leave postive feedback for your free solution today.
Nov 17, 2009 | Brother IntelliFAX 4100 Laser Fax
My mfc8460n brother keeps gets jam steadily now when I'm copying,
you need to reset the life of the drum. Instruction is included when you purchase a replacement drum
Jun 22, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC8460N was working great and now today the scanner won't work. Printer and fax work fine. When I try to scan I get the message "MFC-8460N cannot be found. Please make sure your device is ON and...
Try re-installing the scanner software - if you don't have the disc you can download it. The scanner is a very delicate mechanism so is easily damaged - if the software fix don't work maybe it is kaput
Oct 03, 2017 | Brother MFC-8460N All-In-One Printer
Paper curls on 8460 Brother
The following is Brother's take on your problem. All of their solutions have some merit but the one I'm leaning toward is overstuffing of the paper tray. It's common in most offices (and homes for that matter) to have a tendency to stuff the paper tray when it runs out.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000000618&Sympt=The+faxes+I+receive%2c+copies+I+make%2c+and%2for+documents+I+print+from+my++computer+have+a+curl+or+wave+to+them+when+they+feed+out+of+the+Brother++machine.+What+can+I+do%3f+(paper+curl)&Model=270&ProductGroup=5&Keyword=paper%20curls&ProductID=MFC8460N
Apr 23, 2009 | Office Equipment & Supplies
Brother MFC-8460N All-In-One Printer Logo
73 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
