Question about Refrigerators
Refrigerator side will not cool on Frigidair Model FRS26ZGEW3
  • 534 Answers
2 things could be the problem.. 1 check to see if the fan located on the temp. setting control assembly is working. If this fan is not on the fridge will not cool. if the fan isn't working replace it and problem should be taken care of. If fan is working then your defroster is out.. You can tell if defroster is out due to the big chunk of ice in space between the fridge and freezer where the fan is also located. Parts can be purchased at an appliance parts houseand aren't that hard to install. Good Luck
Dave
Posted on Jul 16, 2009
Where can I get an ownes manual for the gallerries seies refrigeraor
This is a link to the Frigidair support site for manuals, you will need the Model number. Frigidaire Support. Hope this helps FixYa up.
Aug 02, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
What is the cubic feet of a model 25353614300 side by side please.
This should be a 23 cubic foot Frigidair built refrigerator. The actual dimensions usually are 22.4 cu. ft. Sears keeps changing how their model numbers read so I could be wrong. Good Luck, Appliance Specialists
Dec 17, 2009 | Microwave Ovens
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Kenmore refrigerator model 106.54592400 wont cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 16, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS6HR4HW: Refrigerator Design Flaw? It's too warm!
Your refrigerator has 2 thermostats and an electrically controlled air damper. If a technician removed the air damper and someone has not replaced the thermostat for the refrigerator side I believe you have a poor quality service tech and if your refrigerator was worked on with someone with an ounce of a brain they surely would not leave the electrically controlled damper out and would not overlook the possibility that the thermostat probe is defective. Your refrigerator would be an easy fix if the people that were working on it knew what they are doing. You have a minor problem with your refrigerator and a major problem with the technician. Sea Breeze
Sep 11, 2009 | Frigidaire FRS26H5AS Side by Side...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
(Frigidair refrigerator R134a system) 3 months after a new compressor was installed it stopped cooling, it leaked. I found and repaired the leak. Then bought some automotive R134a it had dye,conditioner,...
The stop leak probably stopped up your cap tube system and the filter drier.You can try by replacing the filter drier, vacuum the system to 500 microns and recharge.The automotive 134a is the same as any other 134a.
Jun 08, 2009 | Frigidaire Refrigerators
No cooling,compressor comes on and shuts off quickly
All refrigerators compresors have a relay and a overload thermal protector ,both are located on the side of the compresor behind a black plastic cover atached to the compresor with a metal clip(or just the cover snaps in on the compresor).Unplugged the fridge ,pullout the cover and you'll see the relay and the overload replaced them (no more than $30).If this doesn't solve the problem you have a bad compresor, wich is a much more expensive job.
Apr 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
