Heating & Cooling Logo
Ronald Ryan Posted on Mar 22, 2016
I have a Vulcan quasar 2400 heater model 82E I am trying to find the operating manual.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jun 18, 2009
SOURCE: Vulcan Oil Heater not operating correctly
If the red light comes on when starting, this means that there is continuity in both exhaust heating and igniting elements and the heater cutout is also working.
The most common problems with this heater is coke & soot build up in the bottom oiltray and clogging the bottom air intake holes, to remove this the heater box has to be dismantled.
Anonymous
  • Posted on Jul 18, 2009
SOURCE: vulcan quasar 40 shut down when fan starts up
Replace the fan thermal switch located at the top of the heat exchanger. Unplug the power first as the switch is 240V.
Available from any plumbing trade shops e.g. Reece & Tradelink
Anonymous
  • Posted on Aug 12, 2009
SOURCE: no power
Not sure wot series mine is, but has 2 thermal, non resetable fuses in it. They are plastic cased (brown) with 2 spade type terminals. You can check them with the power off if you are not confident with the mains.
Make sure it is unplugged. Pull one of the spade clips off the terminal and then check it for continuity.
blender719
  • 53 Answers
  • Posted on Oct 08, 2009
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Anonymous
  • 8197 Answers
  • Posted on Jun 20, 2010
SOURCE: vulcan quasar elite heater 2400w, trying to find
May I get the model # so I can get you the right manual
Testimonial: "fast reply thank you"
Manual for vulcan quasar 40 gas wall heater
https://manualzz.com/doc/47948376/bonaire-vulcan-quasar-manual-wall-furnace-owner-manual
2answers
I have just moved house and need the manual for a Vulcan Electronic Gas Wall Heater. Please advise - I'm having trouble accessing this online. Many thanks, Maggie
They all have model numbers Maggie. There are a few in the link
https://www.google.com/search?q=vulcan+electronic+gas+wall+heater+manual
We are Fixya, we aren't Vulcan, we just have a Vulcan category for handy filing. There is no connection here to company reps, but we try to help where we can.
Complete cover or fascia for vulcan quasar wall Heater console model
Contact Authorized Service Center or Authorized Dealer.
3helpful
I am looking for a user manual for a vulcan qasar 2400 electronic [ electric heater ] heater is old...
welcome to Fixya
thanks
3helpful
Vulcan quasar elite heater 2400w, trying to find operating instructions
1helpful
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Vulcan quasar 40 shut down when fan starts up
Top Vulcan Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
