Question about Maytag 7.0 Cu. Ft. Electric Dryer
Very loud metal on metal screeching noise maytag model LDE8414ACE
The dryer still works well, but this noise is terrible. Please help!
  • kathrynpbark Jul 17, 2009
    Thank you so much. Turns out the glides are completely worn off. I will try replacing those. Thank you for your advice
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Loud metal-metal "screeching" sounds will eminate from the front bearing glides, (click on link below), for a picture of the glides. Link provided by www.repairclinic.com, they provide repair parts, disassembly procedures and diagrams.
You may also want to inspect for foreign objects in the front and rear drum seals and in the blower.
Drum rollers may sometimes cause loud noises also.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1309&PartID=1309
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1245880&PartID=1245880
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di400518&PartID=400518
Posted on Jul 17, 2009
Loud noise when the dryer turns on
Well, sir, it is metal on metal, and you did well to stop it. Someone will be needing to take the whole thing apart and find the problem. It may be easy because the metal should show where it was rubbing because it will be shiny bright.
Be blessed.
Jan 08, 2014 | Samsung DV448AEE Electric Dryer
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
- very loud squeaking sound
Hello JewettKann,
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #17B on the drawing) Called a sound damper pad on some models.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE4000AZW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-LAUNDRY&diagramPageId=00004&componentDescription=DOOR&documentId=M0402169&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
If you can get the complete model number off your dryer, you can select the exact line drawing and parts list at the link below to make sure you're looking at your exact model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mde4000&=part+number
I hope you find this Very Helpful and best regards!
Dec 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Loud screeching noise
heatman101
fsj
Nov 25, 2009 | Maytag MDE4806 Electric Dryer
Loud screeching noise at times when in use!
Normally loud screeching noises come from the drum rollers being dry.
They need lubricant, or replacement
Sep 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
'Screeching' noise, Gas Dryer
heatman101
Sep 10, 2009 | Maytag SDG4606A Gas Dryer
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Maytag 7.0 Cu. Ft. Electric Dryer Logo
979 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
