Question about HP Pavilion dv6000z Notebook
HP dv6640BR AC/DC power supply though the battery connector
I have a HP dv6640BR (I'm in Brasil). I connect the power supply but the notebook can´t turn on. The HP technical assistance said that I have to replace the Motherboard and Power / USB connector. With a charged battery I can turn on the note without problem. Is there any workaround to power the notebook through the battery connection? I appreciate your help.
    Scholar:
  • 107 Answers
If I remember correctly, DV6000 series laptops have a modular power connector, meaning that if you pull the laptop apart you can just simply replace the power port as opposed to having to solder it on. Typically this part can be bought on ebay for about $20-30.
Even if there was a way to get your laptop to power through the battery port, that would be dangerous and probably just blow out your motherboard completely.
Posted on Jul 17, 2009
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
Please, Where I find a HP G42-210BR Motherboard electronic schemmatics? My note not star the charge pump to battery charge. Thanks and regards.
You have already diagnosed the;
A) AC adapter (Charger)?
1) You have taken a multimeter, set the Function knob to DC Voltage, and tested the AC adapter to see if it is putting out 18.5 Volts? (DC)
2) You had an assistant gently wiggle the power cord to the charger, AND the power cable from the charger to the laptop?
Diagnosed to see if there is an intermittent reading due to broken wires?
B) Checked out the DC Power Jack that the AC adapter plugs into?
(DC IN)
{ It's a DC Power Harness. The jack has a cable with a connector on the end }
Jack is in good condition? Center Pin doesn't move, outer metal shell doesn't move?
DC Power jack solder connections are good, not cracked?
Then you are looking for the power sensor chipset. It is a power MOSFET,
This is one that is used in a LOT of laptops,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=4210321
The HP G42-210(?)BR Notebook PC is part of the HP G42 series of Notebook PC's.
In the list click on the file name -
Compaq Presario CQ42 and HP G42 Notebook PC - Maintenance and Service Guide.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Regards,
joecoolvette
Feb 06, 2012 | Computers & Internet
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
Dec 08, 2010 | HP Compaq nc6000 Notebook
My HP dv2000 shuts down and does not turn back on. The power cord is connected but the charging light is not on.
Your DC connector on the system board is loose:
Problem symptoms:
If it is under warranty, HP will repair it. If not , read this:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 30, 2010 | HP Pavilion dv2000t Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
Computer does not turn on
Does the Charge light work when connected to the power supply?
Try moving the power connector - battery will be flat and the charge is not connecting properly, the DC connector will need to be re soldered (£30) as a rough guess
Aug 06, 2010 | HP Nc8430 Notebook
HP Compaq laptop won't charge/power from AC due to blown fuse
There's plenty of causes why your laptop would not power up from the AC adapter and won't charge the battery. Here are some possible causes and solutions to this problem:
Number one, if it's on battery power, the battery is dead or the battery is bad and number two the AC adapter could be bad. Let's roll out number one.
1. Take out the battery, remove main supply, hold power button down for 30 seconds. This will drain the charges in your
battery. Put only power supply in, do not put battery in, turn laptop on, put the battery in.
2. If the solution in no.1 doesn't solve the problem, pull the battery out, keep the battery out of the laptop for this test.
Take your AC adapter and check the voltage with a voltmeter. What you want to test for is voltage. Put the meter at 20
volts DC and take the tip, the power jack tip of your AC power adapter. You hold the black, (the negative part) of your
voltmeter on the outside of the power jack tip of your AC adapter and you put the red (the positive part) of your voltmeter
in the hole in the inside of the power jack tip of your AC adapter. Be very careful not to touch the red and the black part of
your multimeter and the power jack tips of your AC adapter together, otherwise it will create a short circuit.
After doing these procedures, if your AC adapter is good it will output a voltage which ranges from 18 to 19V DC on your
voltmeter, depending on the voltage that puts out on your AC power adapter. If your voltmeter doesn't show any voltage,
probably your AC power adapter is bad or damaged. But if your voltmeter shows up voltage, then we have to go to the
next possible cause why your laptop won't power on.
3. The dc jack on your laptop might be bad, if the dc jack on your laptop is bad or not making a connection to the
motherboard then it look the battery is bad as well, because the battery is now not holding a charge or even taking a
charge. Also, even if your AC power adapter is good and when you insert it to the dc jack in your laptop it could not power
up the laptop because the dc jack is not making a connection to your laptop motherboard in other words the dc jack might
got loose, that's why it's not making any connection to the motherboard. The only way to solve this is that you have to
disassemble your laptop, and take the laptop motherboard out and look where the dc jack is connected. After you found it,
take a file tool and file off a spot on the motherboard where you can reattach the power jack and use a wire to reattach
the power jack to the motherboard.
Hope you find this answer helpful. God bless.
http://compunics.blogspot.com/2010/06/podnutz-high-definition-laptop-repair.html
Jun 03, 2010 | HP Compaq Motherboard
I have a DV 9700. It wont power up. No lights anywhere. I tried a friends AC adapter, battery remove, power button press etc etc. Is the power supply replacable? HP repair shop said they will only replace...
It may be the dc connector on the motherboard is broken. Take it to a repair shop and ask them to confirm whether it's the dc connector or your power supply that is faulty before ordering any replacement equipment.
Jun 10, 2009 | HP Pavilion dv9000z Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
HP Pavilion dv6000z Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
