Question about VisionMan Computers & Internet
I am in the process of setting up a barebones VBBI-2N7300 (installing Windows 7 on new sata drive) and noticed that the clear fan on the side and the large muffin fan in the rear are not on. Please advise. I believe the rear fan wires go right to the cpu (through the bundle of wires.) The side fan has a red & white wire with a connector and another that can piggyback with other connectors/wires. It's connected to a mate off the bundle of wires coming from the cpu(female to male). The other connector from it is male; should I have connected that one? I don't remember if I had disconnected it and reconnected it at one time or another while installing components. Then the rear fan-- I never see that one spinning. Is it temperature-controlled? Please advise.
  • 4,806 Answers
There should be 2 male fan connectors on the motherboard, one is for the CPU fan and the other is for the case or system fan, this will marked on the motherboard and are usually white in colour.
The case or system fan are not usually temperature controlled but in some cases you can adjust the speed in the BIOS, the CPU fan however is temperature controlled.
Regards.
Posted on Jul 16, 2009
Windows 7 installation disc doesn't see SATA hard drive
If your motherboard's BIOS is properly configured for SATA controllers and you burned the Windows 7 RC1 ISO image correctly, Windows 7 should recognise and install on a SATA drive without any third-party drivers. Consult your motherboard's User's Guide for assistance in setting up the BIOS properly.
In case Still Having Problem Then Follow Us For Computer Support For On : Computer Support
Feb 06, 2014 | HP Pavilion dv6130us Notebook
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
I installed WIN7-64 on my Visionman VBBI-1PCC00 and there is no sound. I need a driver and I cannot locate the disk. Where can I download it please? I tried VIA 21I and it complained that it cannot find...
Having looked at the spec of your machine, it is entirely possible that no driver exists for windows 7 for that particular hardware. The best way to find out if your system is Windows 7 compatible is to load the compatibility checker available on the Microsoft website. All Windows 7 drivers are digitally signed and the OS will find them from the web automatically.
Jun 23, 2011 | VisionMan VBBI1PCC00 Barebones...
Hello, i have sony vaio VPCEB46FG laptop & i have windows 7 64bit operating system & i want to install windows XP 32 bit but im getting following error "a problem has been detected and...
It is required to install the hard disk SATA drivers in the computer first. Download and extract the SATA drivers in a floppy drive, hard drive or CD on a different computer. Then, retsrt the computer by having the Windows XP disc inserted and beging the setup. During the setup process press the F6 key and enter>enter and then install the SATA drivers. Then, continue with the further setup process.
http://www.sony.co.in/support/product/VPCEB46FG
Select Windows XP Operating System and install the SATA drivers. Once, the SATA drivers are successfully installed you can continue with the further setup process with out errors.
You can also view a complete set of instructions on downgrading to the Windows XP Operating System and installing the SATA drivers.
http://esupport.sony.com/US/perl/support-info.pl?info_id=337#
May 31, 2011 | Sony VAIO VGN-S460 Notebook
When I will going to install win xp(sp2) with sata harddisk its show no dsrive installed on your system
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 15, 2011 | MSI MBOX K8MM-V Athlon64/Sempron Barebone...
Install a second sata hdd to a gigabyte ga-p35-ds3 rev 2.0 motherboard not in a raid array configuration, so I can do a clean install of windows 7 to my new drive and leave xp on my old drive.
ther is no need for a raid array. connect hdd assign priority to the new hdd. install 7 on new hdd,
or
just connect hdd , boot to xp , put windows 7 dvd , instal it on new hdd while u r in xp
if ur new hdd is not detecting just clear c-mos settings
Jai
Oct 23, 2009 | Gigabyte Computers & Internet
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
Blue screen when loading windows 2003 server
if you get the blue screen code and type it in www.dogpile.com you can find some answers there, i would sugest that you reset all the bios settings to factory default, that normaly fixes the bluescreen on instalations, you may need the motherboard drivers for the sata and put them on floppy for the system to install the hard drive drivers.
one problem i do come accross is that sata drives are funny so in most bios settings there is a sata setting that switches back to IDE it was for backward compatability problems.
good luck
May 21, 2009 | Computers & Internet
Pc shuts down during windows xp install
Hi!
Easy problem to solve my freind:)
Do like this, start the installation as you did before, when your pc restarts, get in to bios again and change the first boot from cd/dvd to the HDD. That will solve your instalation problem:)
Good luck to you
Please take a moment and rate my help for you
Nic
Feb 27, 2009 | Jetway Computers & Internet
Computers & Internet Logo
85 people viewed this question
Top VisionMan Computers & Internet Experts
David Payne
David Payne
Are you a VisionMan Computer and Internet Expert? Answer questions, earn points and help others
