Question about Garden
It is a 16HP V-Twin engine, horz, shaft. Was overhauled maybe,carb was bad and replaced, when trying to start it cranks fine except at times it kicks back hard and will stop cranking at times. Both ign. coils were replaced engine has 150# compression on each cylinder. Engine is for a high pressure washer. Key looks good so timing should be good. there are no numbers anywhere for model #.
  • 3,741 Answers
Is your blade attached while your trying to start this engine? The blade has to be attached since lawn mower engines have a lightweight flywheel. The blade acts as a counterweight. What happened before the mower became hard to start and kick back? Did it happen all of a sudden? Did you hit something, then it started to happen?---
Is this an overhead valve engine or an L head engine? -----
IF you do have the blade attached and everything is intact check the following:
Armature air gap---
Valve Clearances-------
Kill wire....temporarily disconnect and see if it still kicks back, its a long shot, but it could be shorting out against the engine.--------
the correct gap between the flywheel and coil the Armature gap. .005 to .015in is sufficient .check out.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Posted on Jul 16, 2009
16hp v-twin ohv vanguard
it seem like your gas line is sucking some were
Jun 25, 2013 | Craftsman Garden
16hp horz vanguard, only starts with pull start,when running the lights won't work......
have a load test done on the battery as it appears to fail when the current draw is high as in starting taking the current needed to run the ignition syatem
Mar 16, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
B&S Model: 303447-1078-31 16hp stops running after warm-up
bad coil it will seem like a fuel issue and the spark will look fine threw the spark plug but with a real spark tester you will see it is a yellow spark instead of blue replace coil and thank me
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
PLEASE HELP MY CARB AND FUEL PUMP DIAFRAM ARE OK I HAVE NO CRANK CASE VACOM FOR FUEL PUMP 16HP TWIN CYL BRIGGS &STRA
do a compression test of each cylinder a bad cylinder will drop the vacuum level a stuck open valve will also cause a drop in compression
Jun 10, 2012 | Mtd Garden
My briggs vanguard v-twin 16hp after initial start up this fall started leaking fuel from the carb into the cyl. and into muffler. The jet is seated and not dirty. It leaks somewhere else in the bowl. ...
The solenoid on the bottom is a fuel shut off solenoid to prevent backfiring if shutting down engine with the throttle still open. If you're leaking fuel into the engine, the float is not closing the needle valve in the carb. remove fuel bowl and replace float, and needle valve with seat.Be sure to blow out all fuel passages
Oct 15, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
What size battery is required for a 16hp vtwin? I used to have a 12hp in my mower so I was wondering if the same battery would work.
any 12 volt battery will work. rule of thumb is to get the one with the highest cold cranking amps "CCA" that will fit.
Jan 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Newly overhauled toyota corolla 2e engine emits black smoke
I have toyota corona 3s engine it smokes black and fuel consuption is high we have changed the engine oil and cylinderhead gassecate but still black smoke is comming what should i do
Jan 21, 2009 | 1989 Toyota Corolla 2 Door
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
