Question about Nintendo Wii Console
Wii remote problem
Wii remote turns console on but at the menu screen the hand does not come up to select different thins so im stuck on the menu screen
  • 48 Answers
Make sure ur senser bar is plugged in, the wii remote has full charge and the wii remote it connected proply
Posted on Jul 16, 2009
  • 1 more comment
  • designdreams Jul 01, 2011
    I'm having the same problem and have already tried these solutions. Any other ideas?
  • Kyle Jul 03, 2011
    Press the little red button in the behind the plastic clip-on :)
  • Kyle Jul 03, 2011
    and on the wii at same time.
Can't concetting to the internet.
According to ehow, you should do this:
Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • Press the "A" button on your Wii controller to continue from the warning screen.
  • Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • Click the "Wii Settings" box on the right.
  • Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • May 08, 2011 | Nintendo Wii Console
    I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
    Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
    There are two different modes of synchronizing (syncing):
    • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
    • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
    Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
      Standard Mode Synchronization
      Note: Make sure you have placed batteries in the Wii Remote (how to).
    1. Press the Power button on the Wii console to turn it on.
    2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
    3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
      Go to the Next Step (Playing Game Discs) >
      One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    3. Select the Wii Remote Settings option from the Home Button menu.
    5. Select the Reconnect Option.
    7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
    Set Up and Use of the Nunchuk
    1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
    2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
    4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
    May 04, 2011 | Toys
    Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
    5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Jan 27, 2011 | Nintendo Wii Console
    How to recieve internet connection
    Hi. Here are the procedures on how you conect Wii to the internet
  • 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2 Press the "A" button on your Wii controller to continue from the warning screen.
  • 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4 Click the "Wii Settings" box on the right.
  • 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7 Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • Sep 12, 2010 | Nintendo Wii Console
    My console turns on via remote. I can push the left and right arrows but I am unable to select anything on the main menu. I have changed batteries, and tried different remotes. No change. Any suggestions?
    Do you mean that no cursors appear on your screen? You most likely need a new sensor bar. The button presses are transmitted via wi-fi directly to the wii, but the wiimote's position relies on infrared transmission to the sensor bar.
    Mar 29, 2010 | Nintendo Wii Console
    The wii menu does not appear on the tv screen but have green light on the wii console and i cannot close that wii...someone can help me..
    First check your cable connection.
    Eject the disk, if you have inside.
    Unplug the console at the back
    Wait 10 minutes
    Plug it back in
    Turn it on from the remote
    Press reset if it does not show up
    Hold the power button to shut it off
    Turn it on once more.
    If this not help may your Wii need service.
    Oct 29, 2009 | Nintendo Wii Console
    My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
    if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
    • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
    Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
    3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
    Sep 22, 2009 | Nintendo Wii Console
    Hand does not show up on menu
    The main unit is not receiving the signal from the remote,
    It can be a couple of things...
    More than likely you have two remote handhelds. You may be using the wrong handheld to choose the options. Try the 2nd handheld.
    Check to make sure the batteries are charged and handheld is ON
    Make sure the receiver is in plain sight and not blocked
    Aug 07, 2009 | Nintendo Wii Console
    Wii system stuck on the first screen and the hand is not come up
    Are the Wii Remotes Batteries dead? This can be a common problem as well as Wii Remotes becoming unsynced to the Wii. To resync the Wii remote:
    1. Open The Small Door on the front of the Wii and Take the Battery Cover off of the Wii Remote.
    2. Press the small red "Sync" button on the Wii and then Press the Small Red Button on the Wii Remote.
    You should he a "beep" through your TV speakers that confirm your Wii Remote have been reconnected.
    I hope this Helps. Take Care. =)
    Dec 08, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    208 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
