Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Yard Man 21" Mower Pull Cord Won't Retract
The pull cord on my self propelled Yard Man 21" Briggs engine won't retract. Can you tell me what to look for when I get it taken apart? Thank you.
  • 3,600 Answers
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Posted on Jul 16, 2009
  • 34 Answers
Forget the wd-40....it dries out either put oil or pb-blaster...
Posted on Sep 30, 2014
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
How to remove the cord on my lown boy ?
Where the Starter Cord goes in to the top of the motor is what you need to remove. It is where the motor draws cooling air from and it is easy to remove. There are 3 or 4 small nuts (depends on HP, My 8.5 has 3. My 14hp has 4.) After you have it in hand, turn it over and you see the round pulley, take your time, there is a spring that pulls the cord back and sometimes it will just unwind with a lot of noise.
Don't worry as it is easy to do after installing the cord.
Now is the time to take a break, have a cold beverage!.
Then just put everything back together.
OOPS, I forgot to tell you that you can test the cord and retract spring without putting it back on the motor, and if you need to adjust the spring so it will pull the cord all the way in.
Good way to start learning about your mower.
Jun 27, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Pull cord on john deere 190cc 6.75 hp
The housing might be riveted to the engine housing and might need to come off together. Hope this helps!
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Pull rope cord on Yard-Man Mower, gets to a point and seizes. Can turn through it by hand with blade but still stops at that point each time with cord
My mower had the same problem. There was some dirt or debris built up on one side of the blade drive shaft, but once I shot some oil onto the shaft and turned the blade a few times by hand, it ran good again.
Hope that helps!
Apr 28, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
May 30, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
2,095 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
