Question about Trendware TRENDnet TU2 ET100 network Adapter
Hardware problem Well I followed the directions and nothing. I plug it in and the LED lights on it will not even light up. My computer seems to not notice it and I tryed it on all usb ports and I know they work, I have an ASUS motherboard is it compatiable what can I do?
  • ikkenom May 11, 2010
    Have you tried it on a _different_ computer? If it does not work on _more_ than one computer, then it is "dead", and should be replaced. Is it still under warranty (manufacturer's? extended-warranty via your credit-card?)
  • 57 Answers
Connect the adapter on your computer then check the status of the device under the device manager. It should appear under Network adapters or USB Devices. double clikt its icon and look the device status. if you have the drivers installed successfully and you have tried it on different USB port, youmay try installing on another computer to further isolate the problem. If problem persist after installing it on another computer then it only means that there is something wrong with the device.
Posted on Jul 17, 2009
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
The 945GCT-M3 motherboard wireing diagram for the power sw and power led
power connecter has totally 9 pins on the board but actually we have to use only 8 pins please refer the attached image
if you have further any doubts post me
Feb 26, 2012 | E-Machines Computers & Internet
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
When you press the start button nothing happen not light or start up
First remove the battery and put it back in, you want to make sure it has a good connection.
Next you want to check the power adapter. If it has a built in LED light, it should turn green when plugged into the wall. If it does have a light and the light will not turn on or it blinks, replace the adapter. Next, plug the adapter into the computer, does the LED light change? Example, the LED light was a solid green, when you plug it into the computer it blinks. If the light does something along those lines, then there is a problem with the laptop itself.
If the power adapter does not have an LED light, then you need to use a Multimeter to check if the adapter outputs the right amount of power...which should be around 12 volts.
If the battery and power adapter pass the tests, then you are looking at a hardware issue in the laptop. From your description of the problem, I would guess the motherboard has died or that the charging jack on the motherboard came loose and needs to be replaced or re-soldered.
Two things that would stop the light from coming on, No Power or Motherboard is broken.
May 02, 2010 | Toshiba Satellite M45-S169 Notebook
Computer seems to have died..
Hi
Thank you for your query
Please try the following
1) Change the fuse in the power supply plug
2) Remove all cables and battery from the laptop and then hold down the power button for 20 seconds (thats right there will be no power to the laptop) - this is to destat the laptop
3) Retry
4) If te above fails then the faults are as follows
1)Loose DC jack - this can be tested by plugging your power supply in and wiggling the DC jack if it is loose it will move alot
2) Faulty motherboard/CPU
For both the above i would not recommned you do the repair yourself, but book into a reputable PC shop
If this has been useful please leave postive feedback/vote
Feb 12, 2010 | Gateway MT6728 Notebook
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Sir,
  1. Press and hold the power button down for 10 seconds.
  2. Make sure that the power and hard disk light-emitting diodes (LEDs) are on.
  3. Check the power cable connections:
    • From the electrical outlet to the AC adapter.
    • If applicable, make sure the LED on the AC Adapter lights.
    • From the AC adapter to the notebook.
    • Make sure that the power strip is on.
    • Make sure that the surge protector is on.
  4. Try another electrical outlet.
  5. Disconnect any external devices, like PC cards, digital cameras, or external drives.
  6. Disconnect the notebook from the docking station (if applicable). Remove any power strips and surge protectors. Plug the power cord directly from the notebook into the electrical outlet.
  7. Remove the battery and reinstall the battery. Refer to the documentation that came with the notebook.
  8. Remove any newly installed software or hardware.
  9. Remove any additional memory. Refer to the documentation that came with the notebook for memory removal instructions.
  10. Shut down the computer, and then remove the drives. Refer to the documentation that came with the notebook.
  11. Push the hardware reset (if applicable). Refer to the documentation that came with the notebook.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 21, 2009 | Gateway GT4024 PC Desktop
HP DV2036ea i have a blank screen on the computer
Hello there
Description.
When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
  • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
  • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the power cord to the wall outlet.
    • The connection into the power adapter from the power cord.
    • The connection from the AC adapter to the notebook power socket.
  3. Press the power button again to test the notebook PC.
If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
Feb 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I plug my seagate into the computer. it turns on but then nothing
Plug one usb into your computer and the other end into the drive.
If the light comes on, all is good. The computer should install the device for you automatically. To access the drive, go to My Computer and double click on the Removable Drive. Now you can transfer files.
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Seagate Free Agent Go Small 12 GB USB...
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
ALERT LED light - Blinking Amber - Nothing prints, printer not recognized
The blinking amber light means there is a hardware problem. Got that from Netgear's website because we have a similar problem here. I don't know if it means hardware problem in the print server or in the printer. We put the print server on a UPS Uninterruptible Power Supply and that problem seems to be gone. We are in an old factory and the wiring is not so reliable. Maybe you could try this same fix.
Nov 28, 2006 | NetGear PS101 Mini Print Server Print...
Trendware TRENDnet TU2 ET100 network Adapter Logo
109 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
