Question about Samsung Washing Machines
I've got a Samsung Toploader washing machine, model WA 7584 C1. I need a new lid. I stay in South Africa. Where can I purchase one?
  • 441 Answers
You can use a online source such as marcone.com and just have it shipped
Posted on Jul 16, 2009
Can anybody in South Africa assist me on how to use the soak cycle in a whirlpool 9kg toploader washing machine
Without the model number it's difficult to be specific,
but, often the soak programme essentially stops to allow the soaking to happen.
If it is that kind of cycle, you will need to manually advance the timer or push the start button, to progress the cycle after you think it's soaked enough.
Best of luck
Mar 14, 2018 | Whirlpool Washing Machines
I have a Kenmore toploader washer, model 110.27032602 about five years old. When I choose cycle and shut the lid, I press start. The lid locks, but then nothing happends. No error codes but I can tell its...
Time to call service. I suspect something has happened on the motherboard. We just purchased a NEW washer from Sears, and within two months, they had to come out and replace the motherboard. They ain't makin' them like they used to, that's for sure. And if you purchase a new one, be sure to take out a three-year extended warranty.
Sep 14, 2017 | Washing Machines
Eziset washing machine will not start , the temp light bip and flash , any ideas
if its a toploader its a lid lock fault 100 percent youll need a new magnet for lid or if doesnt have a magnet, youll need the lock under the top panel
Jun 27, 2010 | Washing Machines
Kenmore 80 series washing machine toploader - washes but does not spin or drain - water stays in it
The most common cause of the symptoms you describe is a lid switch malfunction.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
Jan 30, 2010 | Washing Machines
LG toploader washing machine alarm signal Lid Open.
The lid switch is bad, not making contact.Replace switch or see where it is not being contacted by the lid or hindges when the lid is closed.
Jan 04, 2009 | LG KU990 Viewty
I have a brand new LG 8KG top loader washing machine
Thank you for coming back to me, yes I have had the problem solved today. A technician came around to my home and made a slight adjustment to the Lid and said it should never give me trouble again. It was a free service as my washing machine was brand new and it started up perfectly and went through it's full cycle with no hicups!
Many thanks,
Billie. South Africa. ( Durban)
Jan 04, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
