Question about Gigabyte GA-965P-DS3 (0818313003027) Motherboard
Strangest Overclock Failure Problem Ever
I'm running E4300 4gb OCZ PC 6400 7900GS 585w psu on DS3 rev 3.3 F12 I've had this problem a while ago where whenever I overclock the pc will just reboot, even if i oc by 1 mhz. After it resets to 1.8 ghz it'd then the system boots to PCI device listing, and it just stays there until i manually reboot. I got rid of this problem by manually resetting CMOS (taking out battery) at which point I figured out the problem was with AHCI since that was the only setting I changed to cause the problem. Gigabyte told me it's problem with jmicron driver but even after reinstalling their own driver it's still not fixed. However, I was able to overclock using just ide. Recently the problem came back, and no matter what I do, including clearing cmos, rolling back driver, upping vcore, different mem timing and settings, if I change clock speed by as much as 1 mhz it reboots and freezes at pci device listing. Furthermore to confirm my suspicion that it's problem with the gigabyte sata control when i tried to format and reinstall vista it said that vista can't be installed on the drive. Only by manually clearing cmos can i get it to even boot and install, but only at stock speed. Think i should just rma? but goddam i don't want to wait a month or 3.... Any thoughts? Another o/c question once i get this sorted out, how come my e4300 has such **** oc? I hear ppl getting 3 ghz on stock hsf, while I got a lapped e4300 with lapped big typhoon and 3 case fans and i can barely get it stable at 3 ghz. i have 80mm blowing air in front and side and 120 over cpu and out top rear. i guess i just have **** luck with cpu and mobos....
  • 1 more comment
  • Makenshi Nov 18, 2007
    Sorry if I was not clear on the motherboard I am using. DS3= Gigabyte P965-DS3 rev. 3.3 (built my own)
    The problem, though, is that it is not just limited to overclocking. Even without overclocking a lot of times the PC just freezes at PCI device listing. When I try to install vista or xp alike the CD/DVD won't read correctly and fail during installation process.
    With that in mind I found out that the problem is actually with the **** jmicron controller gigabyte uses for 2 of the sata device and ide drives. Right now I installed vista using a external dvd drive and currently it's in a rebooting cycle (reboots after crcdisk.sys on safemode), but that is most likely a driver problem that can be bypassed.
    More importantly, though, this means I cannot use any internal cd/dvd drives since I have to disable the jmicron controller to even start up without the system just freezing. Sometimes my Seagate Freeagent USB hard drive also makes my PC freeze at PCI device listing, at which point I have to manually take out battery to clear CMOS again to boot past the point.
    I was hoping to see whether anyone knows this is a problem that can simply be solved by flashing BIOS or updating driver (since it happens even while I don't have OS installed I figure it's unlikely but who knows), or whether I will need to RMA this back to Gigabyte. The second part of the question then would be how long does it typically take to RMA, from the time I ship it to the time I get it back).
    I heard from someone that motherboard manufacturers actually ship it back to manufacture origin (Taiwan in case of Gigabyte). Anyone know whether this is true or not?
    Say if I do priority mailing. Does that mean 3 days+1 week+3-5 days ship back = about 2 weeks between the time I ship it out to time it returns?
  • Makenshi Nov 19, 2007
    tried someone's suggestion of making two partitions and installing vista on the second partition then somehow it's booting to vista fine now. i'm not sure if it's because i flashed the bios or cleared cmos again or that. the overclocking part still remains though (oc, reboots reset to stock speed)
    one new thing though is that since the bios update, whenever it freezes at "pci device listing" it now says "flash rom protected" on the bottom as well. any new insight?
    New Friend:
I also had problems overclocking my e5300! But Here's the solution Download a program called FSB (front side bus) After you download this program it gets a little tricky You need to check your motherboard for the model number ECT and write it down! Example my mobo is a hp with the model # of ics9lprs419dflf
After you have your model # it's time to open (FSB) okay click on the customize tab and then click to the right of where it says clock generator and bring down the list of model numbers if yours is not there don't freak out just yet because in fact the model number I used was not exact neither! But this is where It gets tricky! Read threw all the model numbers that FSB has listed try to find the closest model # to your mobo #s for example my original number ended with FLF so I found the closest #s related to my mobo #s. This is a trial and error process but is proven effective! After you have selected the closest number click set SET FSB! if your computer does not freeze than you have selected the correct model # but if it does freeze manually restart your computer and try a different model #. It took me about 30 different model numbers to find the correct one so have patience! After you have found the correct model # click get FSB after you do this your current clock speed should show up in MHz in the middle right box under where it says Set FSB. Above your current clock speed is a green box with a number /760 mine is 37/760 right under this green box you will see 2 arrows click the right arrow 3 times and then click Set FSB! Now check your current clock speed it will be slightly higher than before! Keep doing this in small increments and check you your CPU's Temperature by using cpuid and make sure your temp doesn't exceed to high you can also download amd overdrive or a program of this sort and increase your fan speeds this will allow you to reach a higher GHz speed! After you have clocked to a ghz that you are happy with with a maintained temp! Your ready to game! Just remember when you shut your computer down your original bios will change it back to its default ghz speed so just Open FSB when you turn your computer on and simply click get FSB then click the arrows back to the desired clock speed and click Set FSB ! Just be careful and watch your temperatures I got my
Pentium (R) dual core e5300 with original heat sink up to 3.00ghz from 2.569ghz! (Just be careful and don't exceed the recommended temperatures for you CPU!
Hope I've helped
Posted on Dec 17, 2012
  • 56 Answers
Understand that not all computers can be overclocked. For one, laptops are pretty much out of the question. Also, any OEM (original equipment manufacturer) computer, such as a Dell, HP or E-machine, will be virtually impossible to overclock, so your best bet for overclocking is to purchase or build a custom system, but keep in mind that some motherboards can't be used to overclock. Now let's begin.
The BIOS. Overclocking is best done in the computer’s BIOS. There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier CPU Clock Ratio
Posted on Nov 18, 2007
  • Tony Clayton
    Tony Clayton Nov 18, 2007
    It depen on if you want to pay ffor over night once they get your board it takes about a week turn around
you only can overclock the the k version and do you still use aircooling like most, sorry i have to sat it, people, first buy a good watercooling forbyour cpu memory, gpu and fets around the cpu. question which brand psu do you use? . i assume most psu are oems with grappy components and why make your processor and memory extra warm, look for the sheets of your gear and see how hast your gear degreades with increases temperatures.
Aug 19, 2014 | Computers & Internet
What is the error message? The CPUs will not overclock on there own, that requires configuration. Some components when not installed properly with cause the computer to boot to a black screen and the fan to speed up dramatically. I've seen memory sticks and display port cables cause this. Check all your hardware and make sure everything is seated properly.
Jul 07, 2013 | Computers & Internet
I want to change the power of my XPS420. Actualy,L375P00 (375w) i search a power with 450w minimum. Can you give me one or more references. Thank.
Sure patrice_gray.
1) The form factor of the Dell XPS420's power supply is an ATX form factor.
(The term Form Factor actually refers to Motherboards, but has been used for computer parts such as the Power Supply, and the computer case)
The ATX form factor for an ATX power supply is approximately 6 inches Wide, 5-1/2 inches long, and 3-1/2 inches tall. (6 X 5.5 X 3.5 inches)
The stock 375 Watt PSU (Power Supply Unit) is held in the computer case by 4 Philips head screws, (back side), and two metal clips.
With the new PSU you can just use the 4 screws.
450 Watt minimum?
Know this; A computer ONLY uses the power it needs, and no more.
If you installed a 10,000 Watt unit, and the computer only needed 100 Watts, it would use ONLY 100 Watts. (Typical power consumed by a desktop computer when surfing the internet)
Do I assume that you're going to install a better graphics card?
If so why not avoid hassles in the future, and install an economical PSU that will be ready for future upgrades?
I would recommend an OCZ StealthXStream 600W.
1) If the temperature of the PSU is kept at, or lower than 118.6 degrees Fahrenheit ,(48.2 Celsius) the PSU is capable of putting out 736.2 Watts reliably,
(The above is the 9th page of the article. Here is the 1st page,
2) It has all the power cables you'll need. (Click on the Details tab)
3) It has a 120mm fan mounted on the bottom, and mesh on the back. Better airflow through the computer case.
4) The price. The one in the link is a Re-certified unit.
This means the power supply was sent back to the factory to be tested to their specs. Once found to be good, it is re-certified as a good unit.
(Could be someone bought the unit, and didn't want it. Newegg then sends it back to the factory to be checked out. They don't want to sell a bad power supply)
Dell Support, XPS 420 main page,
You may find - Removing and Installing Parts - helpful.
BEFORE you begin:
Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static will fry out (Short Circuit) the hardware components inside a computer.
Relieve your body of Static before working on your computer.
Computer unplugged from power, and on a table, computer case open.
TOUCH the metal frame of the open computer case BEFORE reaching inside the computer.
IF you walk away then return, be SURE to touch the metal frame again.
For additional questions please post in a Comment.
Jun 06, 2011 | Dell L375P00 (KH624) 375Watt Power Supply
Wish to overclock a compaq presario 5140 with motherboard model 0434h made by compaq with chipset i440BX/ZA Rev B and southbridge 82371EB/MD (PIIX4E/M)
Most of the shelf systems run a deliberately crippled BIOS so that they can't be overclocked. Chances are you're gonna have to go the software route.
May 07, 2009 | Computers & Internet
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
965P DS3 v3.3 Wont Keep overclock
cmos chip on motherboard might be bad or theres a jumper you need to set to change bios settings. mabey the mobo won't take the the upgrade.
Dec 31, 2008 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Gigabyte GA-965P-DS3 (0818313003027) Motherboard Logo
210 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
