Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Tankless Paloma NG hot water heater shuts down
I have a natural gas paloma hot water heater that was installed 3 years ago. It has worked great in that time, but recently started shutting down mid-shower. It works great for about 10 minutes then goes cold. When this happens, the units "off" at the remote. That is the remote unit is as if someone physically hit the off button and the display, etc... is off. I can turn it back on and it will work - but may shut down again next shower. Any ideas how I can diagnose and fix this?
  • Anonymous Mar 27, 2014
    After installing a new thermo couple, once lit and turned on, it only ran for two minutes and shut down. I re-lit it and turned it on I got a gas blowback and it shut off.
  • 117 Answers
Have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Posted on Jul 29, 2009
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Error Im getting is C8 82
Before calling service tech, copy following link for Rheem-Paloma troubleshoot resources:
C8 is usually the PC board, or could be failed gas solenoid valve.
82 is gas-type-data-failure = program PCB for proper gas type, or proper altitude above sea level.
If this is new installation, Rheem-paloma might tell you to contact the installer.
If this is older tankless that worked before, then things point to failed PC board. Rheem-paloma may send you new PCB for free if unit still under warranty period for defect parts.
Rheem does not post service manuals, but will send instructions.
Hopefully the success rate for replacing your main PC control board will have better outcome than expected when replacing motherboard on your computer.
Perform regular maintenance to avoid some common error codes.
Aug 16, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 16, 2009 | Rheem Paloma Tankless Water Heaters...
Richman gas lp tankless hot water heater. used for infloor heat and kitchen and bathroom hot water. getting c2 and 11 error code. water temp. setting 120. ran great last year. made no changes. we have very...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 09, 2009 | Rheem Tankless Hot Water Heater...
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
Nov 03, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Can a Paloma Tankless water heater run on NG?
Yes you can buy a chaneover kit mainly you have to change the jets best of luck
Oct 07, 2009 | RTO Paloma 7.4 Series Ph28 Outdoor...
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
890 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
