Question about Linksys Computers & Internet
My cable company has my issue down to the linksys router. The hardwire connection back to the cable modem works fine. With the linksys in the mix, my PC doesn't believe we have an IP address. Is there any fix, or do I just need to purchase a new router?
    Brigadier General:
  • 10,406 Answers
Take a paper-clip, straighten it, and insert it in a small hole in the "back" of the router. This will reset the router to "FACTORY" settings. Then, reboot your computer. If you cannot get an IP-address, then it is time to buy a different router -- cheaper than trying to get a qualified technician to "trouble-shoot" your router.
Posted on Jul 16, 2009
I can not make a wireless connection from my laptop. The icon shows network available and my other hardwired computer is ok. I have disable my firewalls but still no connection.
Since you have not given what version of windows you are using, i am giving a generic step to test where the issue is. Please connect this computer directly to the router or the DSL/Cable modem you have and check if it is working fine with internet. If it is working then the issue is not with your firewall or setting. If it is not working even by directly connecting with a wire, then the issue could be with a firewall
Dec 07, 2010 | Linksys WRT160N Wireless Router
Router drops my speed from 8 to 1 mgs when I connect to internet. Works fine when hardwired.
This router ( WRT160N ) has issue with the firmware.
It is recommended that you should upgrade the firmware of the router. Firmware is the software of the router.
connect the computer to the router with the Ethernet cable. Do not upgrade the upgrade using the wireless computer. Download the firmware of the correct model number and version number.
Once you upgrade the firmware of the router, you will need to reset and reconfigure the router according to the Internet service provide.
Click here for more information about router and network
Feb 26, 2010 | Linksys WRT160N Wireless Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
LInksys wrt160n v2 wireless router not connecting to internet
Most cable companies will only allow 1 active device at a time conneceted to the cable modem. When ever you change what is connected to the cable modem you must always cycle the power/reset your cable modem.
When you are reseting the units, always rset the cable modem first, wait until it boots back up then reset the router. If that doesn't fix the poblem then it may be a configuration problem.
I forgot to ask if you are cable or DSL.
Hope this helps
Apr 09, 2009 | Linksys WRT160N Wireless Router
I have a wrt160n router hooked up to a desktop computer and a
Sound like you have a bad network card on the PC or the router ports have gone bad.
Have you tried different ports on the router?
The problem could also be in the ethernet cable.
Try another cable and see if that makes any difference.
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
Sep 15, 2008 | NetGear DG834G Router
Computers & Internet Logo
44 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
