Question about Hotpoint WM56 Front Load Washer
LOUD RATTLE ON WASH AND SPIN REMOVED DRUM COVER AND FOUND PIECE METAL COULD HAVE COME OFF ELEMENT BRACKET. ELEMENT NOW CATCHING ON DRUM
  • Maisie Storey
    Maisie Storey Jul 23, 2009
    Yes this did solve the problem thank you very much but we now have a leak that we did not have before. Still seaching for source. It at the front somewhere
  • 612 Answers
Your leak is most likely in the boot. The rubber gasket between the drum and the front of machine. Sounds like when the element was catching it created a hole in the boot. Common problem also expensive and labor intensive. Sorry to be the barer of bad news.
Posted on Aug 15, 2009
Testimonial: "YOU WERE SPOT ALL ON EVERYTHING STRIPPED DOWN AND FOUND SEVERAL HOLES. A LESSON NOT TO IGNORE FUNNY NOISIES FOR TOO LONG. THANKS GOT A NEW ONE THANKS"
  • Hotpoint Master
  • 3,463 Answers
You will have to remove front panel of washer , and replace the heater, and heater retaining plate, which is the piece that has come off.
Please rate my solution.
Thanks.
Posted on Jul 16, 2009
When on spin mode the machine makes a terrible grinding noise and won't spin on 1200 speed Hotpoint Ultima WT965 7kg
Turn drum by hand, if you feel it catching, its something between the drum and tub, put in through soap draw usually by children. Can be removed by taking out the heater element to get access under drum.
If it feels rough all the way round when turned and it can be lifted up slightly ( free play ) then its probably the drum bearings and seal failed.
Oct 20, 2013 | Washing Machines
Hot point WF451 Issue. I want change the door rubber between the door and drum. How do I do this? Also the machine is making a noise on fast spin as if there is something in the drum catching. I have...
Hi for changing the door seal check out the video section on www.selfix-uk.co.uk there are a few videos on the wf including bearing change which also covers the door seal as well. As far as the noise in your machine it could be almost any thing...if it's a scrapping noise it may be a bra wire caught between the drum and container, if its a tapping noise it may just be loose wires hitting on the cabinet or you may have a coin between the drum and container if it's a loud rattle, you could also have something in the pump housing...it's hard to diagnose noises without actually hearing them sorry
Jan 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
General electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
Feb 25, 2010 | Washing Machines
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Loud squeeking noise on spin cycle.
I had the same problem. Try taking off the agitator and cleaning below thoroughly. I found a little piece of metal wedge in there. Once I removed the metal it spin with no squeak.
Mar 21, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Front loading washer bangs and thumps during spin cycle
hi may i suggest you remove the top cover of machine and check the drum mountings(rubber) and the spring/s that are connected to the bracket on drum have not broken /come off just one other thing ? when machine was installed was the bracket under the top cover removed b4 connecting and using machine ? this bracket is for security/stability of drum whilst being transported see instruction book ? it is not the first time iv'e encountered this bracket not being removed by customer diy installation worth checking? best wishes
Oct 23, 2008 | Washing Machines
Loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Oct 19, 2008 | Frigidaire Washing Machines
Rattle on fast spin
Hi mate the rattle could be caused by a coin are a bra wire regards a coin you would have to take off the main pump hose connected to the drum our else take the heater element out and see if you can find it if it is a bra wire just rotate the drum until you see it and pull it out
Jul 25, 2008 | Hotpoint Aquarius WD63 Front Load...
MAYTAG Heat Element Shield?
not really put the plate back on it helps force the air across and keeps lint out
Jan 30, 2008 | Maytag PYE2300AY Electric Dryer
Hotpoint WM56 Front Load Washer Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
