Question about ICOM Informatique Hm 138 Speaker Mic For M88
Looking for a connector pin out for the HM-138
Can you send us a picture of the kawasaki zx750 carb
Now that that\'s out, this page is all about jetting a motorcycle. I will only apply one set of jets and make one series of adjustments. The motorcycle that this paper demonstrates is a California model 2002 Kawasaki zx-7r. The "Jet Kit" applied is by Factory Pro. For the series of pages I will cover California emissions removal, Adjusting the carburetor float height and a modifcation known as "The float bowl mod" as gleaned from the vast resource known as the zx7r Owners Club Discussion Forum, Perhaps the greatest motorcycle resource known to man.
Step 1 - Preparation
Airbox
Remove the gas tank and air filter until you are looking at the bottom of the airbox.(Upper Right) Clean out the inside of the airbox while you are in here, there\'s no time like the present. Disconnect the the PCV hose from the bottom of the airbox. (Upper Left)Turn out the three screws and remove the airbox (Lower Right).
Put all the screws in a box and get them out of the way! You won\'t be seeing them for a few hours so the further the better. (Lower Left)
Step 2 : Smog
Smog
Removing the California Emissions from your streetbike is *******. For race applications tho, it\'s all good. The California emissions is a bit more complicated than the 49 states setup(upper left), but you might notice that they have only added an evap system to it (Upper Right). Other than that I can\'t tell a difference. What we will be removing is everything emmisions, short the PCV hose that is mentioned above. When everything has been removed join the two reed plate hoses at the top. You can also buy a block off plate from Muzzy\'s or some other race manufacturer. When you have removed all the smog, you should have a box of junk similar to the one on the right, because I intend to put the smog back on, I will be keeping all the gear.
]Finally, plug off the four vacuum lines that go into the head benieth the carbs: Use 5/32" plugs.
Ken Waters\' Patented "Float Bowl Mod"
This modification is the brainchild of Mr. Ken Waters, who was clearly a brilliant technician who has passed away in an unfortunate accident. I don\'t know much about his passing. Speculation is that the accident was not motorcycle related. Reading thru Ken\'s posts on the Zx7r Owner\'s Club Discussion Forum has helped many motorcycle owners, and myself, understand a load more about how bike tuning is done.
Principle: (As paraphrased from Ken Waters)
In order to get the pressure in the float bowls equal to the pressure in the airbox, racebikes enclose the entire carb assembly in the airbox. As logic, fate would have it we are supplied with little hoses that run into the float bowls of our carbeurators. We are going to exploit these hoses to ballance the preasure throughout the fuel system.
Situational Information:
Now, as if knowing the two hoses that appear to come from the top of the carbs and indeed are attached to the top of the carbs are the ones we are going to use isn\'t confusing enough, I\'m going to tell you that they are connected directly to the float bowls which are at the bottom of the carb assembly. When we pull the carbs off later you will see that the tap is at the top, and the orifice is in the float bowl.
Application:
It\'s real easy. Just connect the two hoses that are discussed above directly to the airbox. There are many opinions about how to do this, I chose to destroy as few parts as possible in an effort to keep as many of the stock parts in tact as possible. I melted one end of a leftover vacuum "T" shut (Upper Right) and connected it to the hose that used to connect the evap cannister and intake silencer to the airbox(Upper Left). Again, trying to keep as many stock pieces stock, I plugged off the other line to the airbox with a screw(Lower Right). I do however, suggest using this other line to connect there, as it can provide a better seal to the airbox. I compensate for this by using a hoseclamp on the one I used.
Note: No matter how you connect it, connect the line where the clean air is, between the air filter and the carbs.
Step 4: Install and Adjust
Finally We Work The Carbs!Disconnect the fuel line where it t\'s off into the carbs.(1) Open the throttle assembly on the handle bars and let the slack out of the throttle cable there. (2) Pull the two throttle cables off the carbs and lift the throttle cables from their pirches. Loosen the four mainfold clamps and remove the carbs by pulling out and up at the same time. (3)
Once they\'re out, turn the carbs upside down on the work bench and remove the sixteen screws that hold the float bowls on (4) and remove the float bowls. Place carb assembly on its side to remove any pressure from the floats and measure the float height with the floats resting lightly on the float pin so as not to push it in at all, but not rise above it either.(5) The floats stock should mesure 13mm. We need to change this to 15.5mm for our Jet Kit. Do so by bending the little tab between the floats and the float pin. (Right)
After you\'ve adjusted the float hieght, remove the main jets and emulsifier tubes and replace them with your choice of factory mains and tubes. I chose the 168 outer / 178 inner (Smaller) combonation because of my altitude.(6)
Remove the four black caps on the top of the carbs. (7) Be careful because they are spring loaded! Remove the needle jets and place shims "as necessary" (Consult with Factory Pro or a tuner in your area about this.) My favorite wrench jockey suggested two shims and so far it seems he was right, response is genuinly smooth all the way through. Replace the stock springs with Factory springs if provided.
To finish of the mods, I added a 4 degree Factory ignition advancer.(8) An easy install that smoothes out throttle response even further.
Oct 21, 2014 | Motorcycles
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
I am looking for MCP61PM-HM (Nettle) 9 pin front panel power header diagram
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Pins 1, 3, 5, 7, and 9.
Starting on the Right side at the Top, going down,
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
HarDDrive activity LED.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 04, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
Mpc61pm-hm rev 2.2 manual
There is a brief manual at HP website: HP Support Document
If you need PINs specification try here: FixYa - HP MCP61PM-HM motherboard diagram
Else you'll have to try contact ECS (board manufacturer) and ask them for the manual: ECS Web Site
Jan 02, 2012 | HP Computers & Internet
Kenwood kdc-138 wire color code
I'm not familiar with the color code of this model but I have a copy of the service manual which may help you regarding on the pin-out of the harness. Let me know your email add and I will send you the copy.
Regards,
Jdvillanueva
Jun 17, 2011 | Kenwood KDC-138 FM / AM Receiver
Can hm ta1 camcorder material be transfered to tv for viewing
Yes, you need the mini USB connector, and plug it into the A?V socket on the side. You get a live preview of anything the camera sees.
Jan 26, 2011 | Panasonic HM-TA1 Camcorder (Grey)
MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
Nov 28, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
ECS MCP61PM-HM SPDIF Header
diagram at HP support forum sows board and labels for connectors.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=87&query.id=879674
Oct 28, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
ICOM Informatique Hm 138 Speaker Mic For M88 Logo
135 people viewed this question
Top ICOM Informatique Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an ICOM Informatique Boating Expert? Answer questions, earn points and help others
