Question about Dryers
We have a kenmore dryer model 11068934792 ser. mj3303110 -90 plus series we do not get any heat when it is running
    President:
  • 1,776 Answers
It sounds like you have a bad heating element or thermal fuse. The fuse cannot be reset. If it is bad, then it will need replaced. Often a dryer heating element burns out, but doesn't triop the circuit breaker or blow a fuse. The heating element is simply a long coil of wire. You can check it for continuity with an ohm meter. No continuity means that the element is bad and you will have to replace it. The elements are not repairable. Hope this helped.
Posted on Jul 16, 2009
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore 90 Plus series model 78932790 will not stay running, will not heat up
On your model, you work on everything from the front.
If your dryer is getting 220/240 volts and just runs and no heat, then its either your thermal cut-off or element thats bad.
This link will guide you to how to take it apart to access your thermal cut-off thermostat on the heater housing and heater itself:
http://www.applianceaid.com/whirlpool-dryers.html#four
Please leave me comment, if you need further assistance
THanks for using FiXYa
Rnj VinodKumar
Apr 06, 2010 | Dryers
OUR CLOTHES ARE NOT DRYING TOTALLY ON SETTINGS WE
From the sound of things I would say that your heating element needs replacing, they dont last for ever, its worth while getting a repair man to replace it. your dryer should then work normally. I hope this helps.
Nov 05, 2009 | Cars & Trucks
My dryer runs but no heat . model 110.68932792 . Kenmore 90 plus series type DDOT ELE2406028 EH54
you either have a bad element or thermal cut out is bad check for 220 volts at the element if you dont have 220 then the thermal is bad if you do have it the element is bad i can get you them parts.... whirlpoolpartssurplus.com
Jun 25, 2009 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Dec 17, 2007 | Dryers
Dryers Logo
109 people viewed this question
Top Dryers Experts
