SOURCE: paper shredder not working
perhaps the basket is not in properly. This has happened to me.....
SOURCE: Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
SOURCE: ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
SOURCE: The shredder developed a jam. I removed the bin
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
