Question about GE GSS25JEMWW Side by Side
GE refrigerator Model#GSS25JFMD Refrigerator is at 50 degrees, freezer at 34 with the dials turned all the way up. Any previous experience with this?
  • GE Master
  • 1,606 Answers
Check for frost about 1 foot up on the back wall in the freezer section . Is so , then a defrost problem is there .
Posted on Jul 18, 2009
  • Uma Mysore
    Uma Mysore Jun 22, 2011
    mY ICE MAKER DOES NNOT WORK AND iT LEAKED ALL OVER FROM LAST NIGHT. iI HAVE TURNED OFF THE SWITCH AND WATER CONNECTION TO THE FRIDGE. WHAT IS THE SOLUTION?
Freezer will not go below 20 degrees.
Most likely the defrost heater is not turning off. Either a bad limit switch or a bad timer.
Nov 05, 2014 | GE Refrigerators
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Fridge freezer temperature like to know what is the best temperature
The freezer temp should be between 0 and 5 degrees and the refrigerator section from 34 - 37 degrees.
Nov 16, 2012 | GE Profile PSW26P Stainless Steel Side by...
GE model tbx14sisdrwh fridge. freezer works fine but the fridge will only cool to 50 degrees can anyone tell me the problem thank you.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Temperature is reads 73 on freezer and 34 on refrigerator But... inside all are warm Help
It may be vice versa.
You need to check and make sure that the freezer section is 34 degree. The refrigerator compartment depends on the freezer in order to maintain a temperature suitable for food storage. If it is the case, you defrost heater and thermostat may be defective.
Dec 10, 2010 | GE Profile Stainless Bottom-Freezer...
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator compartment freezing
Experience tells me the design should maintain 40 -34 degrees in the refrigerator section when the freezer is between 0 and -10 You might check this if you have a thermometer for the job, and adjust the thermostat accordingly. Your unit may also have an airflow control (I didn't research) to adjust the refrigerator independent of the freezer.
May 25, 2009 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Ge Freezer not working
with min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Oct 12, 2008 | GE GSS25JEMWW Side by Side
GE GSS25JEMWW Side by Side Logo
783 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
